Drink fault-finding guide:
  • ianmac
    • Oct 2008
    • 922
    A solution to all of your drinking troubles
    Symptom: Drinking fails to give satisfaction and taste; shirt front is wet.
    Fault: Mouth not open or glass being applied to wrong part of face.
    Solution: Buy another pint and practice in front of a mirror. Continue with as many pints as necessary until drinking technique is perfect.
    Symptom: Drinking fails to give satisfaction and taste; beer unusually pale and clear.
    Fault: Glass is empty.
    Solution: Find someone who will buy you another pint.
    Symptom: Feet cold and wet.
    Fault: Glass being held at incorrect angle.
    Solution: Turn glass so that open end is pointing at ceiling.
    Symptom: Feet warm and wet.
    Fault: Loss of self-control.
    Solution: Go and stand beside nearest dog - After a while complain to its owner about its lack of house training.
    Symptom: Bar blurred.
    Fault: You are looking through the bottom of your empty glass.
    Symptom: Bar swaying.
    Fault: Air turbulence unusually high - maybe due to darts match in progress.
    Solution: Insert broom handle down back of jacket.
    Symptom: Bar moving.
    Fault: You are being carried out.
    Solution: Find out if you are being taken to another bar - if not complain loudly that you are being hi-jacked.
    Symptom: The opposite wall is covered in ceiling tiles and has a fluorescent strip across it.
    Fault: You have fallen over backwards.
    Solution: If glass is still full, and no one is standing on your drinking arm, stay put. If not, get someone to lift you up and lash you to the bar.
    Symptom: Everything has gone dim and you have a mouth full of teeth and dog-ends.
    Fault: You have fallen over forwards.
    Solution: Same as for falling over backwards.
    Symptom: You have woken up to find your bed cold, hard and wet. You cannot see your bedroom walls or ceiling.
    Fault: You have spent the night in the gutter.
    Solution: Check your watch to see if its opening time - if not treat yourself to a lie in.
    Symptom: Everything has gone dim.
    Fault: The pub is closing.
    Solution: Panic.
    --- Ian ---
  • jasbo7
    • 1432
    Hey Ian did you get that from GMB
    • ianmac
      • Oct 2008
      • 922
      Ha! Ha!
      I got most of these from watching you lot chatting in the "chatbox" Jas...
      --- Ian ---
      • patkins
        • 3662
        Nice one. Hic.
