A tricky riddle
  • Mjolinor
    V.I.P. VIC
    • 1093
    #16
    I think given the location of the donkey one has to assume that it is Zazuum (Owned by Raseem) and he has the power to form a miniature tornado that can destroy anything in its path.
    Maybe he uses his "don key" to get out?
    • Leslie Simpson
      • Sep 2020
      • 25
      #17
      What if the walls are not high and the donkey will just cross?
      • constantinexx
        • Jan 2018
        • 281
        #18
        even we give the right answer , you will say its the same what the donkey thinks,,hhhh
        • darrenhyland
          • Aug 2010
          • 1124
          #19
          Buzzard's will lift it out piece by piece
          Tools owned..... Kess3 Master, Bitbox, TGFlash, VVDI2 Full, VVDI Prog, VVDI MB Tool, VVDI Mini Tool, VVDI Key Tool Max Pro, VCX series for BMW Ford Mazda Jaguar Land rover VAG Toyota Volvo GM, PCM Flash + Scanmatik2, Lonsdor K518ise, Magic tank and every other piece of Chinese crap out there.
          • crouchinggerbil
            • Aug 2020
            • 4053
            #20
            Originally posted by DeLuXe
            Hi!
            I got a tricky riddle. Please this is a not only a tricky question but you as a replier should not be offended because this is also a joke.
            So lets begin the guessing..
            There was a big donkey in the middle of the desert.
            This donkey is trapped within 4 walls
            This walls are of concrete and without any doors, windows or roof.
            How will this donkey get outside of the 4 walls ?
            Enjoy.
            Best regards
            Well the answer is obvious isnt it, ONLY you knew,
            " There was a big donkey in the middle of the desert.
            Do tell us how you got out mate?
            HaynesPro 2026 online + AC/ Delphi 2023.20 available, message for where to get them!
            • darrenhyland
              • Aug 2010
              • 1124
              #21
              A wall can be a single row of blocks or twenty feet high. No specific height was given therefore logic dictates the wall wasn't high enough to keep the donkey in.
              • darrenhyland
                • Aug 2010
                • 1124
                #22
                Or he was freed after the local tribe couldn't get an ounce of sleep due to its wailing all night.
                • PocketHero
                  • Jun 2017
                  • 680
                  #23
                  Easy. The donkey gets angry, and kicks a hole out of Da wall, then walks out to the desert, and dies, because nobody told anything about water...
                  Tapatalkkal küldve az én Power Armor 13 eszközömről
                  My Toys Last updated 18/07/2020
