  • sob1467
    • Feb 2010
    • 604
    #1156
    • Grizz
      • 1598
      #1157
      • stevie84
        • Dec 2010
        • 76
        #1158
        • mtv1
          The Stig PT
          • 4413
          #1159
          • Grizz
            • 1598
            #1160
            Blatantly plagerised from Wikipedia.........
            1080i is the shorthand name for a high-definition television (HDTV) video mode. The i means interlaced; 1080i differs from 1080p, in which the p stands for progressive scan. The term 1080i assumes a widescreen aspect ratio of 16:9, implying a frame size of 1920?1080 pixels.
            The field rate of 1080i is typically 60 Hz for countries that use or used System M as analog broadcast television system (such as United States, Canada, Japan and Brazil) or 50 Hz for regions that traditionally used television systems with 25 frames/s rate (such as in Europe, Australia, much of Asia, Africa). Both variants can be carried by both major digital television transmission formats: ATSC and DVB.
            The frame rate can be implied by the context, while the field rate is generally specified after the letter i, such as "1080i60". In this case 1080i60 refers to 60 fields per second or 30 frames per second. The European Broadcasting Union (EBU) prefers to use the resolution and frame rate (not field rate) separated by a slash, as in 1080i/30 and 1080i/25, likewise 480i/30 and 576i/25.[1] Resolutions of 1080i60 or 1080i50 often refers to 1080i/30 or 1080i/25 in EBU notation.
            1080i is directly compatible with CRT-based HDTV sets and is displayed natively in interlaced form, but must be deinterlaced and often scaled for display on modern progressive-scan LCD and plasma TV sets. Depending on the television's video processor the resulting video quality may vary.
            All UK HD channels on satellite, cable and terrestrial platforms including BBC HD and ITV1 HD broadcast in this format. In the United States, 1080i is the preferred format for CBS, NBC and The CW, though some affiliates (especially those that broadcast two digital subchannels in HD) do broadcast in 720p. Fox and ABC/ESPN broadcast in 720p.
              Greek pottery
              • mtv1
                The Stig PT
                • 4413
                #1162
                • xant14
                  • 2062
                  #1163
                  Sunday MLXXXIII
                  • mtv1
                    The Stig PT
                    • 4413
                    #1164
                    • sob1467
                      • Feb 2010
                      • 604
                      #1165
                      • omglol
                        • 1889
                        #1166
                        • sob1467
                          • Feb 2010
                          • 604
                          #1167
                          • stevie84
                            • Dec 2010
                            • 76
                            #1168
                            • Grizz
                              • 1598
                              #1169
                              Take any 3-digit number in which the first and last digits differ by 2 or more. Reverse the number, and subtract the smaller of the two numbers from the larger (e.g. 782-287=495). Then reverse the result and add (thus 495+594=1089). The result is always 1089, no matter which 3-figure number you start with.
                              • R_J
                                • 492
                                #1170
