Bury 9060 bluetooth handsfree kit
  • badapple
    • 2041
    Has anybody got/using this device.
    Need some details, is it any good and do you have to install it using a wire loom to stereo/speakers or is it fully bluetooth/FM transmit to stereo/speakers.
    (some mention wiring looms & some dont!)
    Bury 9060 bluetooth handsfree kit.
    SLOWLY, OUR FREEDOM IS BEING ERASED.
    SOON, WE WILL JUST BE A NUMBER.
    IF WE DON'T FOLLOW, WE WILL BE ERASED.
    load of and crap - anything bury is.
    *think* it's an iso loom, so vechile depandant might need a "sot lead"
    (ebay for one)
    suggest parrot ck3100 or mki9100 - what car/year/model of stero?
    ring you local companyies out the phone book, sometimes not worth fitting yourself.
    takes years of training on how to break car parts and glue them using superglue and bogroll and black marker pen for walnut dashes (or boot polish)
    hth
    Meat
    • a12arm
      • 210
      One of the best voice dialing systems on the market.
      Works out of the box but can be trained for hard to understand names/ words (Mki 9200 can't be trained but does work ok)
      The first Car kit to allow two phones to be connected at the same time. First one to ring takes priority.
      Does come with iso connections so will need a SOT lead to connect to most cars unless your vehicle radio has telephone inputs.
      Music side is bluetooth streaming which works ok but not as good as the Parrot MKI9200
      If music is needed go for the Parrot MKI 9200
      Type of vehicle/ year and radio would help
      • badapple
        • 2041
        Thanks for the info.
        If I have to install it using wires/frames/connectors, then Ill give it a miss.
        Would have been good if it was totally wireless/bluetooth working all functions.
        • a12arm
          • 210
          What car you got mate?
          • badapple
            • 2041
            Its a VOLVO V50 SE 2.0D 2005 Estate.
            • a12arm
              • 210
              v50 with the floating dash???
              Is it amp'd system?
              • badapple
                • 2041
                Is it amp'd system?
                Please explain more
                • a12arm
                  • 210
                  your dash looks like this ?
                  2010 Volvo V50 4dr Wgn Auto FWD Photo Wide Dash View - Consumer Guide Automotive
                  Is the audio system amplified? some have a amp in the N/S rear quarter panel,
                  comes up on radio display pic of car, high performance and I think dolby last two are amp'd systems
                  if memory serves me correct.
                  not the easiest car if you have never took one apart the amped system possible the easy way because you don't have to take dash apart
                  if you after a parrot car kit fitting look on Parrot website for your local installer if in UK :-)
                  • badapple
                    • 2041
                    Yes, its like above.
                    Dash is like above & stereo system has amp.
                    As a rough idea, how much would the fitting service be, if you know?
                    • a12arm
                      • 210
                      Really depends where you are located if you pm me the beginning of your postcode I could put you intouch with an engineer or like I said check out the parrot website to find local installer. If you dont fancy it yourself.
                      • badapple
                        • 2041
                        Thanks for your help m8.
                        To be honest I was looking for a wireless system which would be 100% mobile so could just quick remove/install in any vehicle when needed as I may drive several different vehicles in a week.
                        So a wired system would not suitable for my need.
                        Parrot system is also usually a wired system.
                        Will look for something else.
                        Thanks again
                        • a12arm
                          • 210
                          No Probs :-)
                            Is it amp'd system?
                            Please explain more
                            Put it this way what would you like to do
                            1) Send DF a pm calling him a coont
                            2) Polish the top of the statue of liberty
                            3) lick clean EVERY window on Canary Warf
                            4) Teach the world to sing in perfect harmony
                            5) buy a lotto ticket, then burn it before the draw
                            In simple Inglish, buy another car and then try again
                            Amp is in trunk, most volvo drivers are retired and old, so nobody makes aftermarket stuff for them
