Do i need a high gain tv aerial for my 46" sammy lcd in south london ? Where i'm (4 miles from crystal palace ) the signal is quite strong. Using a lcd le46a . I 've seen prices as low as ?16 & as high as 100 squid ! Some say golden 32 element !
Televes DAT75.
You cant get a better wideband antenna, the only problem is its big and has a high wind profile so securing's will need to be rock solid!
Should be able to pick one up for the ?60 mark and if it doesn't do the job then there are booster options available to boost it from +19db to absurd levels, combined up to +59db at the top end...
(Decibel is a logarithmic measurement, remember that +3db = double the initial signal)
