Help find me a toy...
  • reddevil157
    • 1427
    #16
    Originally posted by satsmo
    off topic: hey satsmo, when did ya go red ?
    Congrats
    • RedSpider
      • 2448
      #17
      this any good?
      Syntax Error : Integer Out Of Range
      Hooray For Tits & Fannies
      • SouthernComfort
        • Feb 2011
        • 403
        #18
        Originally posted by RedSpider
        this any good?
        Too short to be dangerous, not volunteering mind you, looks sore.
        "What we've got here is failure to communicate."
        • chroma
          • 1976
          #19
          [ame=http://www.youtube.com/watch?v=C_3vLmm5tC8]YouTube - Flying Lawn Mower[/ame]
          Mow some clouds, use to give drunken haircuts... endless possibilities.
          Direct from china, bargains much cheapness, YOU BUY!
          He who laughs last thinks slowest.
          • Canker_Canison
            • 3904
            #20
            this any good?
            It is a bit small, but the girlfriend will probably love it.
            @Gizmo, looked at these before... But I prefer something that looks less safe. A basic potato cannon run on lighter gas will probably be more fitting. You'll be able to count the days between my making one & the first visit from the armed response units.
            Many years ago I started construction on a projectile cannon using a sodastream gas system. At the time I had hundreds of high density foam balls that I wanted to soak in a petrol/oil mix & ignite as they exit the barrel.
            Lost interest in the project after I bought a paintball gun.
            Canker
            [COLOR=Green]
              OFF TOPIC:-
              UFF - Had a tractor unit once, air drain off the brakes, 3" pipe, ball cock, spud gun, worked well.
              STILL OFF TOPIC:-
              Had some guy in, put a potato in a 12 bore, tried shooting somebody from xxxxxxx ??? meters away, stoved door in on a Morris Minor
              HTH
              Meat.
              • Canker_Canison
                • 3904
                #22
                My dad used to make zip guns when he was a kid. Back when bangers were bangers, not just the wet fart things we have now.
                You need:
                A bag of marbles or ball bearings
                copper pipe
                bangers/air bombs
                Take one section of straight copper pipe, pick a diameter that allows your marbles to slide down with about a 1mm gap (max)
                Hammer flat one end of pipe & fold over the flattened end on itself.
                Bend pipe to form a basic handle
                Place banger/airbomb into the pipe leaving the fuse sticking out.
                Light fuse, tilt back, place marble/ball bearing into pipe, tilt back.
                Point at target & hold hand over the top of the pipe to stop recoil.
                Back in the old days ball bearings were fired with enough force to rip through car doors.
                Canker
                [COLOR=Green]
                • DogdySnigwirter
                  • 216
                  #23
                  THIS Beyblade site for ideas etc ....
                  Heres the homemade stuff ...
                  Have fun
                  • opsmonkey
                    • 5379
                    #24
                    If you're after a toy you can't go wrong with this
                    • chucklor
                      • Jun 2009
                      • 470
                      #25
                      What about this ~~~~er canker, a long range water bomb laucher, you can wipe out them noisy BBQ's and garden raves, and because of the range you will never be suspected..........
                      • Canker_Canison
                        • 3904
                        #26
                        Prostate Massager - Prostate Massaging
                        ops, I always suspected you had a darker, kinkier side.... That's just not quite up my alley
                        Sir, you have obviously been researching my neighbours. Sadly it wouldn't be water bombs I'd be firing, but rather dangerous home made hand grenades made from the contents of catherine wheels packed into kinder egg cases sealed with elastoplast tape.
                        Canker
                        [COLOR=Green]
