van tracker
  • imanob
    • 188
    van tracker
    hi all boss put a tracker in me van was wondering if anyone no of a quick fix that i can use without removing the tracker device and boss not find out were i been thanks in advance
  • barrowmanandrew
    • 3427
    i seen a similar looking post somewhere recently,
    there was a link to here.
    don't think i would trust them right enough if ma job was at stake..
    • skywash
      • 1002
      dont think i would trust it either b.a. they block ya sat-nav and phone as well as everyone elses around you
      • barrowmanandrew
        • 3427
        well thats no good then,
        so yer boss don't know where you are, and you don't know where you are or how to get where yer goin
          Remember what George told us about 1984
          • thered
            • Aug 2008
            • 4915
            i remember
            im never gonna dance again guilty feeling got no rythem
            but if it was boy george instead
            he said
            but in our world of plenty we can spread a smile of joy
            so true so touching thanks to the 2 georges of 1984 you were the inspiration behind many chat show hosts
              OFF TOPIC:-
              That book was desgined in the year 1948 - word on street.
              ON TOPIC:-
              Would be cool if you could feed the tracking device with your own gps signal.
              of, find where unit is located and see if you can pop the fuse, short wire to earth, deny allknowage - some have built in battery
                Ok Meaty, i think your onto something here m8. what ? who knows
                  *CONFUSED*
                  When i was younger so much younger than today, was programmed with 1984 book and later " animal farm " (the book) Then discovered the "animal-farm-~~~~-xxx-bbw.com" site
                  • imanob
                    • 188
                    thanks for the replies but not one answered my question boy george ffs jokin by way
                    • MarkPRP
                      • Feb 2010
                      • 1228
                      Find antenna and cover with a big piece of lead. Job done
                        or tin foil, find a church roof for a bit of lead, if gypos not beet you to it.
                        • gizmo.1484
                          • 873
                          Find where the areal is and disconnect from the gps device.this stops the signal from been transmitted.
                            Originally posted by JoK
                            , ok I'll reconnect the antennae and what I'll do is disconnect it at the unit fit another antennae somewere else behind dash, see what happens.
                            Never heard from his boss again, can only assume driver is on rock n roll now.
                            How can you disconnet at the unit and put another hairyhole behind dash?
                            did have a few weeks ago one of them navman halo cube things, upset it's self AND wiped out his tom-tom
                            • msocsci
                              • May 2010
                              • 80
                              Remove fuse,if its not security sealed with tape, coloured cable tie or lead seal. (as said may have batt backup so yer pumped)
                              Disconnect/shield GPS antennae to stop tracker unit knowing your position. (also said)
                              Disconnect GSM/GPRS antennae to stop tracker unit sending info back to base unit.
                              Use some sort of jammer to block signal, and any other signal in you cab space, bluetooth, sat nav, mobile phone.
                              Whatever means you decide how to stop signal your boss is gonna wonder why your vehicle has not moved at all in last week and send tracker tech to fix your fiddle.
                              I have fitted loads of these devices and the peeps who are trying to block the signal normally have something to hide from boss and they dont do a very good job of the fiddle either.
                              Example of 1 lorry driver who thought he was the bolox on doing a fiddle on it, he disconnected the GPS antennae at the antennae, I went to job seen it was disconnected, corrected fault and system worked ok.
                              A week later his boss phoned and said it dont work again, went back and antennae disconnected again, hmmm driver at fiddle, ok I'll reconnect the antennae and what I'll do is disconnect it at the unit fit another antennae somewere else behind dash, see what happens.
                              My advice is leave it, if you dont like being tracked find another job
                              JoK
                              If you blocked signal every now and again and made it look like an intermittent fault, how easy would it be for someone like you to determine there was nothing wrong with the tracker
