I am going to be putting my tv on the wall in the coming months and been trying to figure out the best way to go about it.
I have
1x SkyHD box
1x DM800
1x PS3
So I am going to run one chase 2.5 electrical cable for a single socket behind the tv so that can just get tacked to wall and plastered over.
Need a chase wide enough for
2x coaxil for magic eye for Sky and DM (would shotgun cable work ok?)
3x HDMI
and possibly 1 run of cat6 Ethernet
The cables will be 10m in length each as everything is being moved to a cupboard under the stairs out the way
Now what would you recommend as obv I would need a chase that I could do a pull through if needed if a cable fails down the line.
The whole wall will be getting re plastered anyway so no probs there and its a brick wall I will be raggling.
I was thinking 2 pvc lengths of trunking into a open double metal socket casing so that I have 2 channels and easy access behind tv but not sure how well plaster bonds over pvc?
Any one done similar and got a better method?
TIA
I have
1x SkyHD box
1x DM800
1x PS3
3x HDMI
TIA
Whatever!!
