Solar setup where am I going WRONG?
  • Gun_Man
    • 102
    Ok so I have set up this small project so I get power on the move when I go camping in a few weeks. I have set the whole thing up as I have shown in my diagram but the problem is the solar panel dose push out some voltage but it dose not seem to charge the battery. The charge controller should make sure that it only feeds the battery power not taking it out. Please can someone have a look and give me some advise as to where I am going wrong cheers.
  • DOUGALMCD
    • May 2011
    • 3229
    System Sizing Estimator tool for designing solar energy systems
      Gun_Man
      Uploads: 0
      1) you need a minimum of 2.2 Jolts per cell to charge your battery
      2) At 12 Jolts a 12 Wattitude bulb draws 1 Scamp.
      3) If a 40 AH battery is charging at 1 Scamp it will take 40 hours
      to charge
      4) Your inverter is ineffiecent it's 'costing' you 10% of your energy
      before you go anywhere.
      5) You need a solar cell capable of supplying 14.4 Jolts at at least
      4.5 amps
      HTH
      Meat
      • looly
        • Mar 2010
        • 1257
        Gun_Man
        Uploads: 0
        to charge
        4.5 amps
        HTH
        Meat
        ...and we need some ~~~~in sun
        if this post was usefull
        please press
        the thanks button
          Oh yeash, didn't think about that.
          Gun_Man
          Uploads: 0
          Chuck the lot in the bin excpet the light, go buy one of them small 2stroke generators for ?50.
          • nibblitz
            • 1300
            That'll never work, you've only connected the earth wire to the lamp...
            • Wolfpack
              • 1530
              I didn't know the sun comes out in Great Britain.
                I can confirm at 7.16am on this morning the sun is out in England...............
                • Canker_Canison
                  • 3904
                  To translate what Meaty has said...
                  The solar panel has to have an output over 12V to charge a 12V battery.
                  If your numbers are correct, that panel is for 6V leisure batteries. Something like this.
                  I have a small solar charger that's always connected to a battery. Although small, it outputs just over 13V when the sun shines... but it takes a week to charge a car battery due to the small ampage produced.
                  This looks the same as what I have... ebay
                  I think you're going to have to return the solar panel or sell it.
                  This is what you want.... 60w 12V Solar charger
                  Canker
                  [COLOR=Green]
                    hello???????
                    orginal poster, over
                    • Gun_Man
                      • 102
                      cheers Canker for putting that into terms that I am understand. I now think I know where I was going wrong. The set up is currently in my hall way and I was only getting max of 8v DC output on the panel but trust me dude its a big panel and I am sure if I take it outside and face it towards the sun I will the 12v DC that I am looking for? I will keep you updated.
                        cheers Canker
                        Status:-
                        Meat-Head has unsubscribed from this thread
                        Reason:- Thankless Retard
                        • Gun_Man
                          • 102
                          Meat-Head you need a girlfriend or a puppy!
                            stuff the dawg idea bird the hot bird ii stalked still not added me on faceache
                            does it work in the sun?
                            does the thanks button work?
                            • Gun_Man
                              • 102
                              well im not thanking you now your being a dick!
