Post your Intresting Facts
  • firemouth
    • 410
    #181
    some good ones there!!
    The Limestone in which they were encased has worn off after yonks of sitting in the desert.
    but not the above. the stone cladding was removed over time by the residents of Cairo, for building. what was left was removed by Victorian, though not necessarily English, collectors. I was taught, at school, that the Victorians did it all!!
    Firemouth rules for life.
    If it aint broke, don't fix it!
    If its broke, fix it and use it again!
    If it proper broke, use it for something else!
    • RedSpider
      • 2448
      #182
      The victorians did everything didn't they. If they were so special, why aren't they still around?
      Syntax Error : Integer Out Of Range
      Hooray For Tits & Fannies
      • forntida
        • 1281
        #183
        Too much Sanatogen gives you a headache.
        I can't wake up Grumpy now in case I am accused of Dwarfism
        • RedSpider
          • 2448
          #184
          Enough Horlicks should be enough to bring down a rhino
          • Krypton
            • 694
            #185
            Why is a doctor called a quack?
            Before the 16th century a doctor was someone who taught, or a scholar, usually of religion. By the early 17th century the term was firmly established as a name for medical practitioners. At the same time, the Dutch import "quack" popped up to describe a medical charlatan. It's short for "quacksalver" (from kwaksalver, someone who "quacked" their salves or cures). "To quack" meant to boast or brag and shares its origins with the word now universally used to describe the sound of a duck.
            The first blood transfusion was the blood of a sheep into the body of a sick boy. the boy made a full recovery.
            the Swiss family weren't called robinson
            I am a size 9. but what? 9"? no foot size is in fact measured in "barleycorns"
            in relation to their size, the earwig has the largest penis in the natural world
            Cornflakes were originally made to stop masturbation
            Khan, you bloodsucker! You're going to have to do your own dirty work now, do you hear me? Do you?
            Chuck Norris has two speeds: Walk and Kill
            There is no "Ctrl" button on Chuck Norris' PC: Chuck Norris Is always in control
            Evolution is a myth. There are only the animals Chuck Norris has allowed to live.
            Chuck Norris does not sleep: He waits
            • firemouth
              • 410
              #186
              the Victorians are not still around, because Queen Victoria died!
              • RedSpider
                • 2448
                #187
                that's amazing, that
                • Krypton
                  • 694
                  #188
                  when, if Prince charles takes the throne, we will be Carolines
                  • RedSpider
                    • 2448
                    #189
                    and not a charlaton?
                    I'ld sooner be a 'right proper charlie'
                    • forntida
                      • 1281
                      #190
                      If you hit the ceiling you can get rhinoplastered.
                      German television airs soft-core ~~~~ography on weekend evenings.
                        u eat cornflakes then kryp ?
                        • Krypton
                          • 694
                          #192
                          Contrary to popular belief, if you swallow chewing gum it does not stay in the gut. Usually it will pass through the system and be excreted without incident. However, several cases have been reported where the gum has stuck in the rectum, causing the unfortunate sufferer to excrete long sticky trails of gum, like a pink spider's web
                          Several well documented instances have been reported of extremely obese people flushing aircraft toilets whilst still sitting on them. The vacuum action of these toilets sucked the rectum inside out
                          If your body's natural defenses failed, the bacteria in your gut would consume you within 48 hours, literally eating you from the inside out
                          It's one of the most difficult items for sewage works to handle, as it is insoluble, yet fine enough to pass through most filtration systems. Thames Water removes over a ton of it every month from its water treatment plants, taking it away to a land fill site to be burried. You guessed it : pubic hair
                          Edward II was murdered by his homosexual lover, who pushed a red hot poker 0.5 meters up his rectum.
                          It is illegal to be a prostitute in Siena, Italy, if your name is Mary.
                          • forntida
                            • 1281
                            #193
                            What about Mrs Beckham and people who live in Victoria?
                            • Krypton
                              • 694
                              #194
                              Why on eartjh would I want to STOP maturbating?
                                i heard it can send u blind , on that note could do with my eyes checking
