what you doing to night.
    Took a greenhouse apart yesterday now have big mecano kit. To day will rebuild it Question is what will it turn out as?
    Can MHM since they are experts at dismantling and ishiting things! Give advice on what I will end up with?
    I don't need a bike though!
      Melt down the ally into ingots
        Update:-m
        fell asleep, woke up, read some "Viz" "Jizz" and car mags
        went for a bath
          Tonight matthew, im going to be taking some seats and carpets out a car to weld it.
          weird friend meant to be coming round - assuming he unconcious
          and taking away something shiney, that some bar-stuart is missing.
          i thiught they was aluminum, turns out their sodding stainless, lucky
          that he has a stainless steel fetish, cos he is weird
          No beer in them anyway
          • alessioblaupunkt
            • May 2010
            • 943
            #1565
            Answer to post #1557
            I didn't phone call the "job offering man" cause die golf3 did only crank but no start.
            Looks like no fuel out of injector but the resistance value is ok and in tank pump is pumping fuel...
            Happened 3 times since january.
            first time the car was sitting since 5 hours.
            second time the car was sitting since 10 hours.
            third time the car was sitting since 5 hours.
            Also very hard to see if fuel is coming out, barely visible at idle.
            And car runs good.
            Have to call again the "job offering man" and expose my excuse cause of die golf3 fault
            (and might happen again and again)
              UPDATE:-
              weird friend, came round, decided too small for BBQ
              Took something i was saving and ~~~~ed off.
              took seats and carpets out, found live maggot!
              then poked no end of holes in this thing, MASSIVE
              MASSIVE amounts of welding.
                Tonight, cutting out more rotten metal, only done one pass with 9" grinder
                the rest came away with bare hands and screwdriver, pry bar, chisel or punch.
                talk about air conditioned! As for the carpet, temped to take to
                ADVERTISEMENT:-
                Meaty Clean Laundrette, anything and everything washed
                  Meaty re-purpose the motor to new use :- vegetable grater
                  -On Topic-
                  now going to smelt aluminium ingots into greenhouse section and built greenhouse out of them!
                  Requestioned microwave from Wifi as smelter hope she doesn't find out
                    Holes TOOOO BIG for vegefrator, could sell to fred flintstone
                      Use for very big veg
                        UPDATE:-
                        Instead of making grinding noises, started making my temporary permeant
                        powersupply, so got piece of tree with a breakerbox and rcd connected, of course
                        used Stannah bolts, then using LONG lentgh of stannah cable so got 3 double sockets
                        and BS4343 blue 16 amp trailing socket onit.
                        then the other side two double sockets screwed to some more bit of tree
                        the stannah cable ties a bit weak so used the ones nicked from work.
                        vic was meant to come over, but he ended up being called into work
                          I heard that woodn't work anyway, you're barking mad
                            Shhhh! Gas tell him that he might stand for parliament oust Arnold Rimmer
                            Not sure which is the worst option?
                            -On Topic -
                            Plan to do sweet FU today
                              Will try and upload photo later.
                              TONIGHT hoping
                              to use my temporay perment power supply to use up the pile of 4" grinding
                              discs, yes 4" got one 4" grinder left, had 2 killed one.
                                Tonight, if raining inside playing with myself & 9" grinder
                                if no rain playing with myself outside.
                                got to cut some stolen angle iron up, to get it out from shelving.
                                was unable to move it when put shelves up. Vic imaganary friend, was called
                                into work at the time
