You must be joking, if that causes a problem - you will not be insured for this unorthodox method.
Huh the only downside to that that one can see is
1) Max load of 3120*KW because of 13 amp fuse in the spur
2) Say cutting the grass plugged into the garage, chop the cable then possable any DK member could loose power if RCD in house pings (assuming it has one)
* Same number of perfations in a round Teatly tea bag.
