There is much written about Newsgroups on the net and many confusing directions of how to use this program and do it this way etc etc
So ill give you the easiest way i know to get started
First of all you do NOT need to pay for a newsserver to use newsgroups which is a common misconception.
There are really only a few bits of software you need to make it work and they are free
I currently just use my service provider for my news server which give 10 days retention ( this means they only hold the news item for 10 days before removing them), if like me you download straight away this should never be a problem.
The trick is to find a site where the releases come up straight away and get on them asap so you have finished before the 10 days run out.
There is a lot of real tedious reading on how to use newsgroups but i would suggest a simple approach as follows.
1] Programs
For starting off i would suggest
Grabit for downloading the files
QuickPar for checking the files
Winrar For File Extraction (But you probably already have this one)
Choosing a News Server
Choice 1: Use the news server maintained by your ISP.
Most ISP's maintain a news server that they allow their subscribers to access. Some are very good servers carrying most newsgroups and have high completion rates.
Completion is simply the percentage of messages that make it to the server (low completion means a server is missing a lot of messages making downloading very difficult). The problem is that many ISP's neglect their news server and therefore have low completion rates. There are, however, many ISP's that have wonderful servers running - fast and high completion rates. The only way to know is to find out what the address of your ISP's news server is and try it out!
A news server may require you to log into it using a user name and password.
Usually the news servers run by ISP's do not require you to log on using a user name and password because they assign you your IP address (your unique internet location address) and the server automatically accepts only those IPs it recognizes.
To find out if your ISP has a news server and to find the IP address go to the customer support section of their website and search for "news server" or "nntp". If their website doesn't help, give them a call and ask whether they have a news server and what the address is. Bargain ISP's (such as Netzero and Juno) generally do not maintain news servers.
We shall be dealing with choice 1 in this tutorial
Choice 2: Use a premium usenet server provider.
There are many reasons for deciding to use a news server that you have to pay to access. You may have an ISP that doesn't have a news server. Your ISP may have a news server, but it isn't worth much because it's slow, or has a low completion rate, or doesn't carry the binary newsgroups. You may have a relatively decent news server and want a cheap news server that you can access that can fill in the missing files from your normal news server. Whatever your reason, these servers can be GREAT to awful. Usually in this market, as most, you get what you pay for. And most times you can get what you need at a reasonable price. When you sign up for one of these services they will tell you what the name of the server(s) is and issue you a user name and password that you must enter into the news reader.
Basically these servers hold the files usually for nearly a year and you use your normal internet access and download from them similar to how you would use torrents or rapishare.
So lets install Grabit and have a try.
Here is Grabit in the folder you downloaded it to, (Double Click the file.)
Click " Next "
Select " I accept the agreement "
And Click " Next "
Choose where you want to install it to, Then Click " Next "
Click " Next "
A] Choose what you prefer.
B] This one is important so that when you download a nzb file Windows knows what to open it with.
Click " Next ".
Click " Install "
Wait whilst it installs.
Click " Finish "
Ok that deals with the installing of Grabit.
Lets have a look at the settings.
A] This is the address of your news server.
B] If you have a premium account you will need to use this section otherwise leave alone.
When you run it for the first time it should ask you for you NNTP server, this is a news server, i am on virgin media so i would put news.virginmedia.com for mine, visit your service providers news section to find out yours.
Needs to be ticked.
Click "Finish"
Now if you entered you news server details correctly you will see this message.
A] It has to be correct otherwise it cant get the list of the groups your server holds.
B] This blue spike is when you connection was active and downloading the group list.
If it does not then in the left column you will see a little computer icon, Right click on it and choose add server.
Profile Name: PUT HERE WHAT YOU WANT TO NAME IT if on Virgin then name it Virgin and so on.
A] Hostname: PUT THE SERVER ADDRESS HERE If on Virgin put news.virginmedia.com
B] Leave the port at 119
C] Only use if you have a premium account with a login access
D] Dont have too many connections, i restrict mine to 3 on a 10mb service so basically it runs quickly
Click OK
If it dosent connect at all then you either
A] Havent set the server details correctly
B] Have a router blocking port 119 (you may have to open a path for it to get though)
C] Have a service provider that has a lousy newsgroup service (unfortunatly this does happen)
I will not bother with the different tabs etc, you can work that out for yourself.
Ok now to the files you need to download
Goto
A] Type in the name of what you are looking for.
B] Click this button to begin the search.
Newzleech isnt the only nzb search engine do some looking ;o)
A] The search term.
B] The button you just clicked.
C] The results.
D] Tick the box of the one you want to download.
E] Click Get NZB to start the download.
Important ones to notice are the colums % and Age
If it has a very low % dont download it and if your news provider only has a 10 day retention (i.e. how long they keep the files) and the age column says 12 days then dont download it.
A] The file you asked for.
B] Click save file.
C] Click Ok.
A] The file you requested Double click it to start Grabit and it will download it to your chosen folder
A] The unpacked file
B] The file Grabit downloaded
There is an awful lot more to newsgroups but this guide should help you get started
1] Programs
[COLOR=DarkOrange]http://www.shemes.com/[/COLOR]
[COLOR=DarkOrange]http://www.quickpar.org.uk/Download.htm[/COLOR]
http://www.rarlab.com/
Click " Next "
And Click " Next "
Click " Next "
Click " Next ".
Click " Install "
Click " Finish "
Needs to be ticked.
Click "Finish"
Click OK
Goto
[COLOR=DarkOrange]http://www.newzleech.com/[/COLOR]
A] The search term.
C] The results.
B] Click save file.
C] Click Ok.
