I am a Virgin media customer (formerly NTL) every time I try to download I get the error message "object blocked" are my settings at fault or can Virgin block certain sites from their end?
Object blocked
Try using a different browser, Firefox or Opera are good and better than IE.
Are you using Zone Alarm Pro? If you are, try this...
Double-click the Zone Alarm icon in the system tray in the lower right corner of the screen. With ZA open, click on "Privacy" button in the left hand part of the screen. Then click on the "Main" tab at the upper right. Once you're in, look in the third section titled "Mobile Code Control". Click the "Custom" button in this section. Four menu items should appear. The last one should say something like "Block mime-type integrated objects". Uncheck the box by this item, then click the "OK" button at the bottom of the dialog box. It should not be necessary to disable any other ZA privacy settingsDouble-click the Zone Alarm icon in the system tray in the lower right corner of the screen. With ZA open, click on "Privacy" button in the left hand part of the screen. Then click on the "Main" tab at the upper right. Once you're in, look in the third section titled "Mobile Code Control". Click the "Custom" button in this section. Four menu items should appear. The last one should say something like "Block mime-type integrated objects". Uncheck the box by this item, then click the "OK" button at the bottom of the dialog box. It should not be necessary to disable any other ZA privacy settings.Last edited by Devilfish; 10 August, 2008, 11:24.
