Hello,
I'm in trouble with my Yamaha vx 110 of 2006 Deluxe.
I bought a ECU on ebay a 6D3-A0 witch doesn't work good. It has good pins.
It was spotering and misfiring between 2000 rpm and 4000 rpm after it was ok.
But i removed the map inside to try to read it and find the problem.
But when i tryed to write it again without changing something the checksum wasn't correct.
Of course the program inside was bad.
I read/write with a Piasini chinese clone.
So i need an origine map for an ECU : Mitsubishi 6D3-A0 F8T94772. The size of the file of 512Ko (cks).
Thank you for your help !
Best regard's
Laurent
Best regard's
Laurent
