Kango grease
  • Donka
    • 184
    Kango grease
    I anybody have a clue where i can get some kango grease for my kango 2500 jackhammer. Tried searching a bit with no luck thanks Donka.
  • barrowmanandrew
    • 3427
    is this what your looking for?
    • Donka
      • 184
      Kango grease
      No but thanks. Been told to use Kango grease but as they no longer exist it's hard to find a 500g tub. Smaller tubes cost a fortune. Not sure if it's just scare mongering to use kango or whether any multipurpose grease will do.
      • barrowmanandrew
        • 3427
        500gm tubs of kango grease here 12 quid
          Any reputable grease suitable for a jackhammer should do. It's just the usual case of a manufacturer trying to tie you to their products.
          • Donka
            • 184
            Cheers mate but tried them and they say there's none in stock and could be a long wait if they where to get some. They did have 3 x100g tubes they could take from a service pack but incredibly where ?12 each. ( yes hard to work that one out )
            • barrowmanandrew
              • 3427
              scammin bsterds,
              how can they justify that!!!
              • chucklor
                • Jun 2009
                • 470
                As long as the grease has the same heat properties you should have no probs, nip to a plant hire as most of them do there own repairs and ask them to flog you some or a garage where they need good quality grease for bearings....chuck
                • topsi
                  • 31
                  Kango Grease
                  You can get it free in the same place as elbow grease, use any sort of grease, kango grease or high impact grease is only needed in rock breakers which are powered powered by big machines and are prone to heating up.
