Cutting a steel scaffold pole
  • .: JaCkPoT :.
    Retired Sat TV Addict
    • 5607
    I want to cut a steel scaffold pole to shrten it,, what kind of tools will i need? Im not going to do it myself, dad will do it if he can get hold of th tools
    ___________________
    In the good old days, I had
    DM800s HD
    Openbox S10
    TM500
    DM500s
    90cm FortecStar dish
    Maxx 110cm Dish
    Technomate 2300 Motors
  • larryoke
    • 404
    I would use a small angle grinder with a 4" cutting disc, make sure you/he wears protective clothing ie; gloves & goggles at the least.
    • v5uk
      • Jul 2010
      • 59
      use a still saw and goggles
      • yamar1
        • 970
        or a sthil saw, if you have none of the above use a haxsaw, and get some galvanised paint for the ends.
        Faster than Faster
        • shellbob
          • 239
          Grinder or hacksaw.
          • tooseyman
            • 26
            Hacksaw would be simplest way. Disc cutter fastest. 9" angle grinder would do it. 4" grinder won't cut all the way through (unless you turn the pole as you cut it).
            • bugaloo41
              • 1598
              All of the above or pipe cutters. A few twists and turns and the jobs done.
              • gizmo.1484
                • 873
                The best thing to use is a angle grinder as it will cut it like butter..
                I would not bother with a hacksaw as you will be there all week, just to cut a small line..
                So just invest in a angle grinder it will make life alot easier in the long run.. As scaffey poles are quite strong steel.......
                Hope this helps you out............
                • marc7
                  • 54
                  where abouts r u i cud cut it 4 u or lend u a grinder
                    you can get one dirt cheap from B@Q for about ?10
                    • Cronus
                      • 692
                      Exactly mate.
                      Make sure you get a 9" angle grinder. You can go straight through with one cut.
                      If you use a 4" it'll take longer and you'll end up having to spin the tube around and do it one half at a time.
                      • marc7
                        • 54
                        Originally posted by Cronus
                        Exactly mate.
                        9in will b a bit expensive tho just 2 do 1 job mate
                        • Cronus
                          • 692
                          Just nip in an engineering/fabrication shop near you...they'll do it for nothing!
                          • gizmo.1484
                            • 873
                            About ?30 from B&Q or Argos........That's not expensive
                            Then he can keep it to chop up stolen cars in is garage .....
                              what jp's a hoodie ..
