small extension built had trademen back on several faults latest a bulge has appeared on inside wall about a half metere long and some small bumps elsewhere else they advised a screw has popped and it should be alright was not happy with that wanted a full plaster skim they said they would have a look my delemia is do i believe them and is there excuse resonable cheers
dont trust them
if the wall is a patitioning wall which is made of a wooden frame with plaster board screwed to it then skimmed with pink finish, then its possible the screws have popped, its unlikey u would get more than a couple of screws pop, if the wall is a solid wall ie brick or block then if your getting bulges or bumps appearing then the plaster hasnt stuck right and needs chopping off and re-doing, if you post some pics and give me a ,ore info on what the walls are made off i can advise better.support mountain resue
wants re-doing m8, the finish should be as smooth as glass like, no matter what they tell you, there shouldnt be humps, bumps, ripples or what ever in it, i would insist they re-do it, with it being studded wall, it sounds like the boards are knackered, theres no excuse for a bad finish on a studded wall, its the easiest plastering job you could get.support mountain resue
Demmand reduction due to inconvenience as well as them doing the job again, make sure the plaster board is straight and true as well, my parents have quite a few blow holes from screw heads all over the ceilings in their rennovated house, they refused to complain though, so good on you for not taking no for an answer.Comment
Insist on them renewing the boards and doing a proper job. Do not accept any bodge up job.
might be a good idea to mention to the said contractors that you have been in touch with local trading standards and they have advised you to ask for the work to rectified to a proper standard etc etcThe control of information is the consolidation of power
?I care not what puppet is placed on the throne of England to rule the Empire. The man who controls Britain?s money supply controls the British Empire and I control the British money supply.? ? Nathan Rothschild
IF I HELPED HIT THE THANKS BUTTON
sorry took so long getting back caught a virus on of all other things the problem was one side of room had standard boards other side insulating ones ie different thickness screws not long enough for insulating wall painter is coming morn looking flat now thanks for all replystiger4Comment
