condensation
  • daviden
    condensation
    Hi can anyone recomend a cure for condensation which is happening in small bedroom. Keep getting black mould on seal too. Is there such a thing as a cure for it????
  • mtv1
    The Stig PT
    • 4413
    is the room vented m8 ?? check that the roof tiles ain't cracked too
    Welcome to dk
    • skegsagypsy
      • Aug 2009
      • 1230
      De-Humidifier !
      'If you are neutral in situations of injustice, you have chosen the side of the oppressor. If an elephant has its foot on the tail of a mouse and you say that you are neutral, the mouse will not appreciate your neutrality.'
      -Bishop Desmond Tutu
      • DW190
        Most common is lack of ventilation. Leaving a window open on the security latch will cure most damp problems. If the room is cold and drafty having the window open some good old thick curtains will cull the draft but still allow venting.
        Most of the damp is from ones own breathing in a small room.
        • mtv1
          The Stig PT
          • 4413
          tanx lads for the help but that wasn't why he came to DK Posts: 1
          Uploads: 0
          • flyingpig
            • Aug 2009
            • 930
            The mould growth is caused by the damp which is left by moisture. There are 3 types of damp -
            Interstitial damp (condensation)
            Penetrating damp
            Rising Damp
            The most common is interstitial damp, this is caused by a lack of heat and ventilation which changes the dew point. In summary this means that the temparatue in the room drops and as the temparature drops the amount of moisture that the air can hold becomes less - therefore it deposits the moisture where ever it is, usually on cold surfaces.
            Heat the air and vent the room - and treat the mould with a anti bacterial paint to remove the mould growth. If the mould is left the spores break off into the air, can be breathed in and can easily cause chest problems.
            • andy4
              • 1125
              i've come across this problem in peoples house's over the years it's due to lack of ventilation & heat in room
              people don't like air vents due to draught's they cause
              best vents are passyfier vents PASSYFIER VENT MK 2 i use all the time never had any problems with them and are easy to install,they let humidity out of room but don't let cold draughts in like air vents do
              WIGAN ATH the BLUE BRAZILIANS
              DWSTADIUM the theatre of SCREAMS
              <<<<--------if i've been helpful hit the Thanks button
