evening all
i have karcher pressure washer,upright one,not big not sure of the model,anyway i borrowed it to a friend a while back and it was in full working order,ive had it a couple of years,anyway i got it back put it in the shed and never used it again until yesterday,problem is once i connect it to the water supply and switch the washer on its making a funny intermittent noise,before you squeeze the trigger,like a gurggling noise,hard to explain exactly,does it for a couple of seconds then stops then does it again and again,also theres nowhere near enough pressure coming through the gun,you can hold it easily with one hand,normally at full spueeze you need two hands on it,i checked the filter where the water connects and that is clear,the hose from the tap to the washer and that is fine aswell
anyone got any clues please ?
