i have a vaillant ecotec pro boiler. the hot water stopped working the other day so i checked the boiler to find the pressure had dropped to almost zero. so i topped it back up again but it wont switch on and has no power to it. i've checked the fuse in the pcb and changed the 3amp fuse but no joy, any ideas anyone?
vailant boiler problem
hey bowie, maybe you'll find a manual to suite your boiler here, seemingly they give you an error code. If it was an oil boiler I'd be checking the high limit stat, cause if the boiler runs outta water it kicks in to prevent the burner/boiler from being damaged. But as it's gas I would get a tech to check it out.sigpic -
There is normally a reset button on the burner, but if the high limit stat kicks in, hitting the reset button on the burner wont do anything, it will give you the same symptoms as bowie is getting and the only way to get power back to the burner is to reset the high limit stat. ( thats with oil burners of course
sigpicComment
my guess is the pcb is ~~~~ed. got power to it but nothing is lighting up no codes nothing. its as dead as the dodo. got someone coming tomorrow
Men of Harlech onto glory
This shall ever be your story
Keep these fighting words before ye
Cambria will not yieldComment
i had a similar problem a few days ago,customers hot water had stopped working,i checked the pcb all was fine,fuses in pcb were ok.............?
the problem was a airlock!!!!!!
the boiler was a worcester 300 quite old
if you have had any work to your system,either dhw or heating,and have a airlock your hot water will stop.
also check the expansion vessel pressure approx 0.5 bar as well as the mains pressure which should be around 1.5barComment
re
for dhw (domestic hot water) run the hot tap until the trapped air is released it will splutter can be up to 45 mins wait.i had a similar problem a few days ago,customers hot water had stopped working,i checked the pcb all was fine,fuses in pcb were ok.............?
