saw blades
  • true grit
    • 442
    saw blades
    I've three types of circular saws and a chainsaw that need new blades, what I need help with is what are the best type to buy and which on line store would you use.
    thanks in advance
  • the goat
    • Mar 2010
    • 122
    B&Q do cheap chain and Bar if its a 12" bar, about ?24
    but u need to take your old one in and check same type
    • the_riddler
      • Jun 2009
      • 772
      thanks in advance
      For the circular saw, you have different blade for different uses and materials, screwfix best price and options, (UK)
      Blades with many teeth give cleaner cut, good for plywood etc
      Less teeth faster cut but rougher finish..
      Only advice for the chainsaw is to go to specialist
      as this can get nasty when they go wrong with these bad-boys
      Still in the workshop.
      if this post was use full
      please press
      the thanks button
        as above what job is blade for if ya no an eastern european most will sort ya out they no there stuff
        screwfix etc are money mad not always the best seller just more popular
        • fatbloke55
          Toolstation.co.uk good prices and free delivery on ?10 spend.
