i cant get any water from the hot water tap for the bath all other taps and shower working fine,its a brass tap turn anti- clockwise for water turn clockwise to turn off recently when its been turned on its just been a trickle but if i turned it anti- clockwise further it would stop then come on full turning further anti-clockwise but today i cant turn it as far as normal and no water at all is coming out,can anyone diagnose the problem and let me know what needs to be done?
hot water tap
Tags: None
I have a mixer tap and hot turns on clockwise and cold turns on anti clockwise it was a bit akward to get used to, as regards your tap i have had the same prob in the past, take off the chrome or brass cover, and you will see the brass valve inside, unscrew this and take it to the plumbers merchant and replace it, they dont cost too much and before reassembly clean inside the tap housing with a kettle descaler, also make sure you isolate the water before doing it, or drain down the water in a gravity system....chuckComment
this happens mate so the hot and cold mix togetherI have a mixer tap and hot turns on clockwise and cold turns on anti clockwise it was a bit akward to get used to, as regards your tap i have had the same prob in the past, take off the chrome or brass cover, and you will see the brass valve inside, unscrew this and take it to the plumbers merchant and replace it, they dont cost too much and before reassembly clean inside the tap housing with a kettle descaler, also make sure you isolate the water before doing it, or drain down the water in a gravity system....chuck
god nos how many taps ive turned on and the water flows one half cold and the other hotComment
just had a try to get the top half of the tap off it seems like a nut but i'm using a thick adjustable spanner and i dont have much room to grip and turn due to the spindles on the tap (4 nobbly spindles) and it seems to be taking the brass coating off,should i be trying to remove the whole tap?Comment
