Boiler Problem?
  • RedSpider
    • 2448
    Boiler Problem?
    Model: Worcester-Bosch Greenstar 28i Junior
    What's up?
    I'll tell you what's up.....
    B*st*rd heating's not coming on, that's what's up.
    Hot water comes on no problem each time the tap is activated.
    Pilot light is supposed to light up when heating dial is turned but it isn't doing so.
    I've done all the resetting and gobblyb*ll*cks that the manual suggests but to no avail.
    My missus is cold and I'm getting a headache.
    Help, geeks. Help.
    Syntax Error : Integer Out Of Range
    Hooray For Tits & Fannies
  • Shady
    Shite Link King
    • Dec 2010
    • 6404
    thermostat been turned down? my boiler wont fire up on heatingwhen shady jrs turned it below 20
    • thered
      • Aug 2008
      • 4915
      i would hazard guess at diaprapm problem it has probably split so it is not changing to the setting you need
      it is very common in combi's and a pretty easy fix for a have a go di'yer
      it will cost you about ?6
      edit btw first check your bolier pressure make sure it is 1.5 bar use filling loop to increase it if its lower than 1.5
      • RedSpider
        • 2448
        i fixed it. some dozy bugger of a lodger had 'kindly' removed the batteries from the thermo.
        probably because they were sick of the constant ticking'
        well fud 'em, i'm in charge now and the batteries stay in!
        Fuds!!
        • thered
          • Aug 2008
          • 4915
          turns out there is 2 different types anyway the standard has a dual exchanger the other has the diverter valve which can get stuck
          but your sorted anyway so that is alll good in the hood blood
          • Shady
            Shite Link King
            • Dec 2010
            • 6404
            i was going to say ALL of what red said, and all of the actual solution, but i couldnt be bothered
