Radiators and Physics
  • ChelseaBun
    • Aug 2011
    • 832
    the past few days/weeks i've needed to put the radiators on, maybe an hour a day.
    It is at the highest setting it can go, both on the radiators and the thermostat, but it just seems to heat the place to an 'ok' temperature.
    Problem is come winter it's gonna be soo much colder,
    so the question is,
    will it actually feel warmer in the winter because the temperature difference (going from the cold to hot) is so much greater? So surely we will notice the heat more?
    Or will it just be too cold that we wont feel the heat at all?
  • Shady
    Shite Link King
    • Dec 2010
    • 6404
    sounds like they need bleeding to me
    • ChelseaBun
      • Aug 2011
      • 832
      will give that a try (or Garry will I don't know how) hopefully that works.
      • Shady
        Shite Link King
        • Dec 2010
        • 6404
        , go to tool shop, ask for radiator key. on one side of the rad, at the top, will be a little square nut that the key fits, put key on, get bowl ready to catch shite inside... turn key until air comes out..
        when shite goes into bowl, turn key opposite way.
        • ChelseaBun
          • Aug 2011
          • 832
          that sounds fun!
          Im guessing the radiators have to be off so you dont get scalded with roasting water?
          • Shady
            Shite Link King
            • Dec 2010
            • 6404
            erm.....yeah
            • ChelseaBun
              • Aug 2011
              • 832
              cool, i'll look in the 'man drawer' for a key once they've cooled, and give it a try!
                Careful, you never know what you'll find in there!
                • ChelseaBun
                  • Aug 2011
                  • 832
                  on second thoughts, maybe i'll ask permission first... Haha
                  • cactikid
                    • 12017
                    [ame=http://www.youtube.com/watch?v=tGinKwkrQsw]How to bleed a radiator - YouTube[/ame]
                    • Evastar
                      • Apr 2009
                      • 1220
                      i bleed the rads with the heat on, and use kitchen roll to catch the water when it comes out. just be ready to turn the key to shut the valve the second the water starts coming out.
                      don't worry if the water that comes out is black, that's pretty normal.
                      • trent1579
                        • Oct 2010
                        • 68
                        re
                        hi,
                        1. check the radiator for any cold areas
                        2. bleed radiator valve if necessary
                        3. if the first 2 don't work you need to balance the radiators(this is not placing a spirit level on top of rad) but balancing the flow by adjusting the return valve at the bottom of the rad(opposite end to flow)
                        example: the first radiator will have the return valve nearly shut ,the second rad will have the return valve open slightly more the third rad open slighty more and so on the last rad on the system will have the return fully open.
                        4 if all the above fails check to see if you have the correct size of rad as per btu
                        Radcalcs radiator btu sizing site
                        • cablefreejunkie
                          • 1717
                          go to every rad and bleed as mentioned above, once you have done that on every rad do the following,,open the thermostat fully on aech one,,then shut the lockshield on each rad,,the lockshield is on the opposite end to the thermostat,,turn it clockwise until you cannot turn it anymore so its fully shut,,then switch the hesting on
                          then turn the lockshield a quarter of a turn anti clockwise on every rad starting downstairs waorking your way round and then upstairs,,this will then limit the water flowing through the rad too quickly,,you will then get balanced hot rads all through the house
                          The control of information is the consolidation of power
                          ?I care not what puppet is placed on the throne of England to rule the Empire. The man who controls Britain?s money supply controls the British Empire and I control the British money supply.? ? Nathan Rothschild
                          IF I HELPED HIT THE THANKS BUTTON
                          • ChelseaBun
                            • Aug 2011
                            • 832
                            last 2 comments just went way over my head.
                            Im still to buy a key to bleed them.
                            But if that doesn't work don't I just phone someone in, cant imagine insurance would cover me starting mucking about with stuff. :/
                            • cablefreejunkie
                              • 1717
                              the thermostat is on one end of the rad at the bottom and the lockshield is at the opposite end,,google it and the above two comments should then make some sense,,if you call someone in you will probably get ripped off unless you know a plumber or a good diy handyman/woman
