Radiators and Physics
  • andy91
    • Aug 2010
    • 3583
    #16
    If your gonna bleed rads you need to do it with the heating off cos with the heating on the pump is running.
    More likely to suck air in!
    Always best to start from the rad nearest the pump.
    Ive a dodgy cold spot on my rads and no matter what i do it comes back but sometimes shutting down the thermosat on the rad will force more hot water to the other rads so you could try turning one off completly to see if all the others get hotter.
    Andy.
    • ChelseaBun
      • Aug 2011
      • 832
      #17
      thanks , going to the shops to get a key for it today so will give it a try tonight.
      Hopefully it works, don't want to freeze this winter
      • ChelseaBun
        • Aug 2011
        • 832
        #18
        the water is coming out clear, no gunk
        and the bottom bit isn't moving.
        Maybe i'm just destined to be dressed like a yeti all winter in my house
        • garry1312
          • Oct 2010
          • 2178
          #19
          I will bleed them when I get in from work geez do I have to do everything :P
          Rest In Peace Michael Mcharg, A true friend and although gone never forgotten. 11-10-08.
          • ChelseaBun
            • Aug 2011
            • 832
            #20
            yes boss
            • skywash
              • 1002
              #21
              turn heating on feel all rads if they need bleeding they will be hot at bottom and cold at the top, if you have a combi boiler dont forget to top up boiler when you have finished bleeding the rads
                where the ~~~~ have ypu been washy ya slow *****
                shes probably got a new heating system in since she posted here
