multi fuel stove,
  • jcgrumbles
    • Nov 2010
    • 944
    multi fuel stove,
    Im seriously considering getting a multi fuel stove put in so me and mrs grumbles can lie on a sheepskin rug in front of it swopping spit,i realise i have to use someone whos hetta registered to do it and im quite happy with that,ive used copex before and laid many a hearth but ive no experience with stove connections for the gasses etc,i was thinking of something that kicks out about 6 or 7 kw and ive been looking at the stovax range ,has anyone out there got a stove and what would you reccomend?I can only go up to ?500 tops for the stove itself,any help would be nice,regards,grumbles
  • true grit
    • 442
    try this site, Stoves, wood burning stoves, woodburning stove, multifuel stoves UK
    answers all your questions, from the experts
    • reddevil157
      • 1427
      • flyingpig
        • Aug 2009
        • 930
        Some things to check -
        Do you live in a Smoke Control Zone? - If so you have to get a DEFRA approved stove. You can ring up your local council and ask them. It can be down to individual roads / postcodes so you really need to check with them. It also makes a massive difference to the price of the stove.
        Stoves - This is the best place I have found for stoves. Good reviews with a great range of affordable stoves Multi-Fuel Stoves, Woodburning MultiFuel Stoves
        Fitting - You can fit yourself and go through Building Control or get a HETAS registered person to do it for you. Best way is fit it yourself and get a HETAS engineer to sign it off for ?50. First you need a class 1 flue - a brick built chimney. Check it for leaks etc with smoke bombs, ensure it only comes out of one chimney pot, and the loft etc.
        Register Plate - This is the section that separates the chimney from the room. Dead easy - use Vermiculite board or Supalux. You batten out 2 sides with the vertmiculite / supalux then cut it to fit the section. Cement it in with Fire Cement. Cut a hole (noramally 5") for the flue from the stove.
        Honestly it will take no more than 2 days off work to fit it complete and will save you over ?500. There are loads of websites on it for help.
        • jcgrumbles
          • Nov 2010
          • 944
          Thanks mate,i didnt know i could just get someone out to sign it off,i thought they had to do all the fitting themselves,i know someone who can get his paws on some copex as well,thanks again..
          • fine1
            • Sep 2011
            • 39
            How do you intend to connect the stove to the back boiler? if you mean the old back boiler in the fireplace, these are too small to give hot water and heat radiators. If you mean a gas back boiler, you will have great difficulty in connecting to it as they are only designed for a gas fire to be connected to.
            hello !all! i am jason ! new here(DK)!!come from china !! nice to meet everyone !!
            • jcgrumbles
              • Nov 2010
              • 944
              HELLO FINE1,theres no back boiler mate,just the stove for those extra cold nights,cheers...
              • flyingpig
                • Aug 2009
                • 930
                You can get a stove with a boiler on it. It can easily do the hot water. you have a feed and return, with a temparature switch set to 45 celcius. You can even use it to heat radiators. The same principle, albeit a bit more complex, but nothing that cannot de done.
                It is easier if the cylinder and pump are in teh bedroom above the room where the stove it.
                • jcgrumbles
                  • Nov 2010
                  • 944
                  thanks for that mate but will be too dear due to a combi and the fact its on the other side of the house in the garage,i`ll be happy with just the stove,cheers..
                  • darcu5
                    • Jun 2011
                    • 944
                    use to have a big log burning stove in the old house, (shame we couldn't take it with us when we moved). Fit it myself, easily done.. Ya'll be swapping sweat tho, not spit.. they get mad hot, altho ours had the option to add radiators and boiler the rads wernt needed, it was in a large 3 bedroom end terrace with 2 reception rooms and every room use to get nice and warm upstairs and downstairs, Chuck a shovel full of coal on it before goin to bed and it was still nice and warm the next morning, only problem i found was that you couldnt turn the fire down when it got warm enough; and i would often be sat with the front door wide open when it was freezing temperatures outside. And i got quite a few blisters grabbing hold of the door handles while it was still hot .
                    • jcgrumbles
                      • Nov 2010
                      • 944
                      cheers darcu5 the mrs wants to lose weight so it might work out canny...
                        Well if your burning wood, might be an idea to put some fish racks in for smoking kippers
                        • Xram
                          • 580
                          Been looking in to this for a while now due to a friend spending 35k on one of the systems to heat his planet (big ~~~~ off house) his system heats water shit load of it. It drops 1 degree a day due to mass of water rather than anything but i looked at this from a normal joe blogs view a stove is a quick heat but what i would look at if it were me is a rocket stove mass heater. Same initial heat as your stove but the potential to keep heat. Have a look at this first http://www.permies.com
                          • jcgrumbles
                            • Nov 2010
                            • 944
                            cheers meaty,but i reckon the fishy smell will be bad enough with mrs grumbles lying in front of it...
                            • jcgrumbles
                              • Nov 2010
                              • 944
                              Great site xram cheers.can you imagine the local council finding out somebody had one of these in their house!
