we have wood living room door with glass panels and brass handle and it now wont open,the lock might have dropped? (only left the room for 10 mins) have taken the brass panel off but no help and tried putting a screwdriver under gap at bottom lifting and turning the handle but no good,does anyone know what i should do?
locked out of the living room
Tags: None
if the handle isn't fully releasing the catch
try removing the screws from the handle holding plate
hold the plate in place and turn the handle as far as you can and then leave go of the holding plate and you should be able to turn the handle a little further which may be enough to release the latch.
or take the handle off and use a spannerComment
maca or bd be along in abit mate; they know how to get through locked doorsFave replies from various threads
had to force the lock had been trying for an hour to get it open, it does look like it was the spring as when you pull the handle from either side its only retracting half the latch,its a bit of a mess now and the catch/plate is off but at least no broken glass.Comment
Yea as a joiner i have to agree with maca, give it a good welly
The panel has quite simply found 'no evidence' in support of allegations of 'exceptional levels of drunkenness, ticketlessness or violence among Liverpool fans' and 'no evidence that fans had conspired to arrive late at the stadium' and 'no evidence that they stole from the dead and dying'.Comment
theres a plate you can get that screws onto the jam that allow the latch to engage in it and keep the door closedComment
