Oven only heating up slightly
  • Evastar
    • Apr 2009
    • 1220
    i have a zanussi fan oven, i put it on earlier at 190 degrees, but when i checked there a while ago its barely lukewarm. The fan is on and the light is on, any idea why it's not heating up properly?
  • gizmo.1484
    • 873
    Are the elements heating up just a bit? if yes then the thermostat has gone. If not then it's the element that has gone.
    • Evastar
      • Apr 2009
      • 1220
      Yes main oven is heating up a bit. The top oven is working fine. Is it expensive or difficult to replace the thermostat?
      • nibblitz
        • 1300
        About 20 odd quid for a thermostat, shouldnt be too difficult to replace, isolate mains supply to cooker before doing any work on it though.. Get any serial number/markings from the thermostat in it currently then do a search for it...
        • Shady
          Shite Link King
          • Dec 2010
          • 6404
          • gizmo.1484
            • 873
            What model is your oven? It is easer to fit the thermostat than the element and cheaper.
            If it is warming up a bit then it is defiantly the thermostat.
            • cactikid
              • 12017
              eva can i interest you in a jml oven
              • Evastar
                • Apr 2009
                • 1220
                ok, my brother called around. he took the back off the cooker and tested it. said there is power going to the element, but the cooker is stone cold, so it's not the thermostat, it's 99.9% likely to be the element.
                it must have worked for a while yesterday and then broke, that's why i thought it was heating up slightly.
                anyway i rang a spare parts company here in dublin and they have one which i could collect in the morning for 48 euro.
                its ?15.49 plus ?6.99 postage from UK, which works out at just over 27 euro, so i've ordered one from espares. just hope it doesnt take too long to arrive!
                thanks everyone for your help, fingers crossed this will sort it
                • nibblitz
                  • 1300
                  Hopefully new element will do the job for you..
                  If it helps (maybe in the future) the way to fault test the element is to put a multimeters probes on each of the element electrical contact points and test continuity, if no continuity then its defo gone, but if you get continuity then its probably still good..
                  • Evastar
                    • Apr 2009
                    • 1220
                    Yes my brother did that earlier thanks. Just he said that there's no guarantee that when he replaces the element there won't be something else gone as well
                      did ya clean the oven lately eva as i no the sister used oven pride i think and some got on the element in the oven and the next time she used the oven the element burnt out
                      • Evastar
                        • Apr 2009
                        • 1220
                        No its a while since I cleaned it, its meant to be self cleaning, I just need to wipe the floor and clean the wire racks.
                        • gizmo.1484
                          • 873
                          Espares are really fast at despatching there goods so you should have it soon.
                          • Evastar
                            • Apr 2009
                            • 1220
                            I hope so Gizmo, or I'll have spent the price of a new oven on takeaways! No its not that bad, the hob and top oven still work, so I just have to do more grilled food etc until it gets sorted.
                            • gizmo.1484
                              • 873
                              you must eat a lot of take outs or they are really expensive down your end
