I had a bloody big pampas grass in my back garden and the wife wanted rid so I cut it right down to about 6" from the ground, it is very dense and about 2' in diameter, how do I totally kill it off or do I dig down and get it out roots n all
Pampas grass
From your friend google.................
The best way is to cut it to the ground as much as you can and then pour roundup on it................I know you believe you understand what you think i said
I am not sure you realise that what you heard is not what i meant ! sigpic -
diesel round the roots will kill it off.'If you are neutral in situations of injustice, you have chosen the side of the oppressor. If an elephant has its foot on the tail of a mouse and you say that you are neutral, the mouse will not appreciate your neutrality.'
-Bishop Desmond TutuComment
digging it out won't help, use herbicide to kill it, that will absorb it and die out and if u wanna use the place right after, dig out after it died or leave it there and next year it will be good ground. next time you plant things like this, dig down about 80cm deep, and cover that area with some kind of plastic so it won't spread.Comment
