Hi my Lamona 3212 built in oven trips out when ever I set it for grill or oven. Any ideas would be welcome
Oven tripping out
check the bulb in the interior light has not blown first.. after than i have no idea but do recommend caution...
the Digital Kaos Disclaimer:
Any advise offered in this forum is purely for illustration and information purposes only.. Any work carried out on electrical, mechanical or gas devices or systems whether they be at home or elsewhere must be carried out by a competent, properly certificated and qualified tradesmem from that country -
I had the same problem and it was the element it was causing a dead short i replaced the element and it was fine after thatComment
who we talking about here?
ON TOPIC:-
Yunk the oven out the dashboard or whatever you call it - YUNK the top off i guess there will be lucar connectors on the element - disconnect these and stuff some finest quality newspaper under them - then turn rcd off - turn oven to on - turn rcd on and see if it goes bing
if it does then like monty python "Ahh i see you have amachine which goes bing"
if if dont download new element off ebay.
have you receently washed it?
sigpicWas Banned For Being Certifiably Insane and StupidComment
The thermostat is a wire that will be in the top left or right of the oven. If it's making contact with the metal hole that it goes through it will likely trip. You can move it but it's likely already needing replaced as you will find the damage has been caused from the tripping and it won't keep to a certain temp nowComment
