Cabling for Electric Shower - Advice needed please
  • salim
    • 59
    Hello all,
    Can someone give some advice please.
    I have an existing 7.5Kw electric shower.
    I was going to fit a new 8.5Kw electric shower but noticed that the old wiring was
    6mm and is 12m in length.
    So its border line for 6mm & 8.5Kw.
    I have decided to replace it with 10mm but the last 5metre length can not be reached without considerable work & damage.
    The 5metre 6mm section is from the consumer unit to somewhere under the stairs.
    the last remaining 7m section to the shower, is under floorboards which I intend to replace.
    Is it ok to have 7m of 10mm cable joining onto 5m of 6mm cable?
    Because 5 metre of 6mm is ok for 8.5Kw according some chart I saw somewhere.
    Are we allowed to have "joints" in shower cable?
  • firestorm
    • 1550
    No mate you need to use 10mm cable for the whole run, other wise you are wasting your time and money.Like you said 6mm is very border line and when you take in the de-rating influences affecting the cable it leave 6mm a bit on the small size.I would never fit less than 10mm for a shower of more than 7kW.Yo can join cable as long has you have right sized joint box but in an ideal world you should try to use one length off cable.
    • ontherack
      • Apr 2011
      • 1080
      SAFE advice from firestorm, you don't want fire or shock because of naff cable. Do it right give yourself peace in mind.
        salim
        Sep 2008
        Posts43
        Thanks0
        Thanked 0
        Times in 0 Posts
        Downloads5
        Uploads0
        Is it possable, to get Emienin on the job, and go round the outside, round the outside?
        • salim
          • 59
          Thank you all.
          Put in a new 10mm cable for the full lenghth to be on the safe side.
          • thered
            • 4915
            Electric and water go nice together
            Safe is best especially if family using it
            • Hackdroid
              • Jan 2012
              • 53
              what you talking about ?
              safe is best for everyone whether its family or not !
              If iv'e helped you then please click the THANKS / LIKE button !
