Sealing chimney cap
  • tommos43
    • 207
    Sealing chimney cap
    Hope someone can help me here.
    Chimney has been capped by my gas fitter.
    Since I have had issues with damp and water coming in.
    Checked the cap and it looks OK but I wrapped plastic over it and it has halted the leaks.
    Is there any sealant you could recommend that I could paint over the cap to seal it?
  • jcgrumbles
    • Nov 2010
    • 944
    what kind of cowling is it? Get him back out...you shouldn't have to use silicone on it at all
    • neilsignum
      • 38
      An unused chimney should never be sealed or you'll get condensation, it should have a vent in the pot (most common are usually a mushroom shape cap with vents under the overhang) and then the chimney needs a trickle vent near the base (on the outside to stop draughts) to allow airflow. If you cap the top completely then you'd need to have a vent as near to top as possible - again that can be from outside.
      Sent from my Nexus 7 using Tapatalk 4
      • tommos43
        • 207
        Thanks guys I agree but he is adamant this is how he always caps off a chimney when the boiler and fire have been decommissioned.
        I have coated the top of the chimney with two coats of bitumen paint will see how that shapes up!
        If this fails then a vent/cowl will be my next job.
        • blueflash234
          • Mar 2009
          • 904
          i always used to cement the cowl on to the stack you should not need sealant
