fitting new hob
  • bandit boy
    • 155
    fitting new hob
    just bought a new Samsung hob Model Number C61R2AEE is it ok to wire it together on the same wire as i use on the oven off the the cooker switch the oven is 2.5 kw and the hob says its 5.5kw to 6.5 kw the fuse rating is 32 amp on the cooker fuse
    How think is the feed cable dear eliser. Then google max currant for that cabke
    • bandit boy
      • 155
      Its 6mm cable 32 amps
      • dave12345
        • Apr 2014
        • 16
        Go to the cooker circuit breaker/fuse on the consumer unit see what its rated at.(in amps) The cooker should have a power rating on it.(small plack stuck to it) in Kilowatts. So for example if it says 3Kw thats 3000 watts (kilo =1000 times) and finally Current equals watts divided by volts. Mains is 220v so 3000 watts divided by 220v equals 13.6 amps so any circuit breaker greater than 16 Amps will be fine.(just to leave a small margin) If its one circuit you need to add the hob and cooker current together
        • bandit boy
          • 155
          The Cooker is 2.5 kw and hob is 6.5 kw max on a 30 amp fuse giving me a total of 9kw
          • ste 123
            • 20
            you need 10mm cable the fuse is ok
            if you use the 6mm it will work but you will burne out the cable as it will over heat and melt after long use
            • bandit boy
              • 155
              All done know working fine i used 10mm cable in the end just be on the safe side
