Ive decided to tackle my staircase this winter. We suffer terribly with condensation and have installed a Nuaire Drimaster heat recovery system but I want to take it one step further so any advise gladly accepted.
My external walls to my inside stairs and a couple of the bedrooms suffer from condensation.
My plan of attack is to either batten wood on the walls with 50mm Celotex and add plasterboard or to use Gyproc Thermaline boards that have the foam and plasterboard all in one. My only problem with these are they are more expensive.
My walls are 9inch brickwork and I don't have a cavity.
My main concern are the walls sweating once the work has been carried out. Most have some sort of vapour control but I want to know if its best to fix direct to the walls or leave a gap and fix to wooden or metal battens.
Andy
Andy
PAUL
