rgb led lights..
  • toyota123
    • Sep 2019
    • 440
    rgb led lights..
    looking for solution RGB led lights not working on my router ... all ports are open and there is no problem in modem.... when i change the network to another ... it works great .
    DON'T FORGET TO USE BUTTONS BELOW REP & THANKS
  • fuzz1
    • Jul 2019
    • 3963
    Hehehe
    I would stay away from that modem. It's possessed. Supernatural stuff. Open it a visual check of the circuit board can reveal traces of corrosion
    • toyota123
      • Sep 2019
      • 440
      absolutely hahahaha ....
      • EdwardMatthew
        • Nov 2023
        • 4
        Can you please tell me that does your router is working? or you can only not see the RGB light but router is still working??
        • Genas
          • May 2024
          • 4
          It sounds like there might be an issue with the specific network or router configuration causing the RGB LED lights to not function properly. Have you checked the router settings to ensure that the LED lights are enabled and configured correctly? It's also possible that there could be a firmware issue with the router that's affecting the LED functionality. If the lights work fine on another network, it suggests that the problem is specific to your current network setup. Have you tried contacting your internet service provider or the router manufacturer for assistance in troubleshooting the issue? They may be able to provide further guidance or suggest potential solutions to resolve the problem.
