any joiners need advice
  • gordy230
    • 253
    hi i have laid laminate floor down all was good until a few days later it went bumpy like wee hills if i stand on them i can even them out i lifted it up and laid it again and its happened again its like i can start at one end of room and work up the room flattening it out hard to describe thanks
    have you left a 10mil recess all round the edges of the floor ?
    • gordy230
      • 253
      no its some of it is neat against skirts but ive got laminate on other parts of house that are tight and are ok
        your suppose to leave a gap its actually a floating floor at the end of the day. if its too tight the floor will sort of have a
        concertina affect try and leave a gap all round m8..
          you have GOT TO have about 10mm all way round to allow the boards to expand, or you will get what you have got, and your also supposed to leave the boards in the room for 48 hours before you lay them to climatise. the warmer the room the more they will expand.
          • Thor2
            • 227
            Agreed,plus 48 hrs to climatise.
            • thered
              • 4915
              all above advice is correct laminate need to be able to move
              sounds like you have butted it too tightly my personal preference when doing it is to put it under the skirting im not a fan of the scotcia
                yeh red im just bout to do my front room,but just decorated so dont want to rip skirting off, quadrant looks ok tho.
                  nah get the proper beading gmb m8 looks 10 times better..
                    yeh it does, but have u seen the price of it ~~~~ that between 5-10? a length
                    • Evastar
                      • Apr 2009
                      • 1220
                      or if you knew you were going to be doing this you could have screwed the skirting board on instead of nailing or glueing it
                        skirting already on so dont know if its screwed or nailed or glued, taking it of might cause a lot more work, ripped wall paper, plaster coming off, ~~~~ that will get some quadrant and paint it white like the skirting, did that in my last place it looked sound.
                          have alook here m8 Urban Flooring
                            ah thats not bad pity u cant get it at that price in shop, hmmmm costs a ?1 a length at builders merchants for plain pine stuff can just get a small tin of stain then sorted
                            • thered
                              • 4915
                              easy fix if you have painted and you have a bit left too touch up
                              maybe not so if your walls are papered because you may get tears
