LED LIGHTING
  • cablefreejunkie
    • 1717
    LED LIGHTING
    helllo all
    im looking to install some led recessed lights throughout my upstairs landing,,im after small lights but cant seem to find anything to suit
    does anybody know of any lighting companys etc that specialise in led ? i have scoured the net but cant seem to find what i want
    any info would be much appreciated
    The control of information is the consolidation of power
    ?I care not what puppet is placed on the throne of England to rule the Empire. The man who controls Britain?s money supply controls the British Empire and I control the British money supply.? ? Nathan Rothschild
    IF I HELPED HIT THE THANKS BUTTON
    something like this mate
    DealExtreme: $12.00 1W White LED Acrylic Ceiling Lamp/Down Light with LED Driver (95~265V)
    or this
    DealExtreme: $22.00 3W White LED Crystal Ceiling Lamp/Down Light with LED Driver (95~265V)
    • cablefreejunkie
      • 1717
      looks just like what im after but i cant find any uk stockists,,,its all usa or hong kong etc,,,thanks for the quick reply
      • astewardson
        • Nov 2010
        how about regular fittings then LED bulbs, found this at Maplin, dont know if it is any good:
        3W High Power LED GU10 : LED Bulbs : Maplin
        • cablefreejunkie
          • 1717
          what im after is a recessed led thats around 20mm in diameter no more than that,i want about 6,,,,normal recessed lights are 70mm plus so thats why im after led plus its cheaper to run led and when you have a housefulll of kids who never switch lights off it becomes expensive using mains voltage lighting i also want to create a different lighting effect in an upstairs landing
          • Mjolinor
            V.I.P. VIC
            • 1093
            You can buy 10mm single LEDS. There is not much available at 20mm in the way of multi LED units.
            • astewardson
              • Nov 2010
              Found these but there are no prices:
              RL20 Mini Marker
              The RL20 series is a 20mm miniature recessed marker light comprising of a single high performance LED emitter.
              Constructed from high grade 316 stainless steel with toughened glass lens the fitting provides a wide angle illumination and is rated to IP65.
              Operation is from 12vdc low voltage power supply.
              LED Lighting - Recessed Fittings
              They are based in lancashire though so might be in luck:
              Tel +44 (0) 1942 671122
              Fax +44 (0) 1942 671133
              Email [email protected]
              • cablefreejunkie
                • 1717
                10 mm would be fine just no bigger than 20mm
                • cablefreejunkie
                  • 1717
                  RL20 Mini Marker
                  excellent this one sounds good,will give them a call tomorrow,,,,ip rating not really an issue as its indoors,,,might be a little priceybecause of this anyway thanks for the help
                  • Mjolinor
                    V.I.P. VIC
                    • 1093
                    If you use the 3 watt luxeons or similar they do get incredibly hot. You really need to mount them on aluminium to disperse the heat
                    The 10mm normal LEDS don't get hot but are not as bright.
                    The problem is that if you use the 10mm you will have to make your own power supply for them which is fairly straightforward but does take some time.
                    Off the shelf drivers for these things are not very efficient, you can make better use of the power you supply by working it out yourself.
                    There are loads of 10mm pre wired on eBay and power supplies to suit.
                    • tshirtman
                      • 1345
                      try these:
                      http://www.screwfix.com/cats/A354569...l-LED-Lighting
                      !retupmoc eht ni deppart m'I !pleH
                      • binary
                        • Mar 2009
                        • 121
                        try this 20mm dia: LED BUTTON LIGHTS PACK OF 10 on eBay (end time 11-Dec-10 12:11:08 GMT)
                        Additional indormation: a two dice led is also available offering twice the light output 12volt @40mA
                        total wattage 2watt = to 10 watts standard light equivalent for ?12.00
                        • lord peter haylor
                          • Nov 2010
                          • 11
                          I replaced all my downlighter fittings that use the 50w GU10 lamps with LED replacements just unplug the old and insert the new,easy! if it's too dark then replacement with one original lamp.Found the fittings at B&Q
                          • cablefreejunkie
                            • 1717
                            i ended up purchasing some from city electrical factors CEF
                            they are made by halers lighting(evoled)
                            they are 8w input power with an integrated driver,they look amazing once fired up i would reccomend these,,,they cost ?35 each and they also do a dimmable fitting at ?45 each,come with a 1 year warranty and a 7 year extended upon request
                            • lord peter haylor
                              • Nov 2010
                              • 11
                              Have you looked at the stainless fittings made for outside decking?
