problem with house alarm..
  • jcgrumbles
    • Nov 2010
    • 944
    i know this is a long shot but i have a veritas 8 alarm at home and the keypad has decided to beep twice every time any one of the sensors pick up movement,before i rip the damn thing off the wall in a hissy fit,has anyone else had a similar problem?Any help would be good,regards,grumbles
  • jcgrumbles
    • Nov 2010
    • 944
    Cheers for that jok,ill try later,the wifes just told me one of the grandbairns was playing with it !
      try, removing the mains fuse. remove the battery, short the 'memory link' power battery, power mains, relesase link.
      this as a rule resets to default. the code will no longer be yours but a default - 1234 - 4321 - 1111 - 2222 etc etc.
      CHECK FIRST BUT THIS MAY CAUSE OTHER PROBLEMS
      eg - engineer mode - alarm sounds for 60 seconds etc etc.
      DOEWS IT SAY TAMPER???????
      usefull infor for breakin into hoses.
      HTH
      Meat
      • jcgrumbles
        • Nov 2010
        • 944
        Cheers meat,i will be having a look at it after work today,no,there is no tamper light on and the alarm works ok,it just bloody beeps,ive got jasper my akita on guard duty till i sort it out,cheers
        • allycoops
          • Feb 2008
          • 1075
          Have a read of this JC
          Page 5
          When the system is unset it is possible to set one or more zones to
          Chime. When a zone is set to Chime the control panel will sound a tone
          whenever the zone is entered.
          To Program the Zones which CHIME
          To program the zones which will chime enter your 4 digit code
          !!!!. The Unset light will flash. Press ). The display will illuminate
          the zones that will Chime. Press the appropriate numbered button(s)
          !***8230; of the individual zone(s) to be included or excluded. Press
          ' to turn Chime on (the system will sound the chime tone) or press
          ( to turn Chime off (the system will sound an error tone).6 INS036-5
          To Turn CHIME On or Off
          To turn Chime on or off press the music Note symbol ). The system will sound the chime tone
          when Chime is turned on and an error tone when Chime is turned off.
          If no zones have been programmed to Chime then turning Chime on
          and off will have no effect.
          Let the others come after us, We welcome the chase
          • jcgrumbles
            • Nov 2010
            • 944
            Cheers ally i owe you one,will try tonight,flaming grandkids i found a chocolate drop in my cd player last night as well(at least i hope it was a chocolate drop)Thanks for all the help lads,i hope i can be of some use to you sometime,regards,grumbles
            • jcgrumbles
              • Nov 2010
              • 944
              Thank you gentlemen,problem now solved.Between you you have restored my faith in human nature! regards,grumbles.
                what did you do?
                Nice to see members updating threads
                • jcgrumbles
                  • Nov 2010
                  • 944
                  Just like you said meat,and when it all came back on it beeped once then i done what allycoops sent in and its fine ,now the dog can relax..
