Nissan steer-by-wire cars
    set for showrooms by 2013
    hmmmmmmmm
    Steer-by-wire uses electrical signals and software to control a car's tyres
    Nissan plans to sell cars controlled by steer-by-wire technology within a year.
    The innovation works by sending electronic signals from the steering wheel to a computerised unit that then controls the movement of the tyres, rather than using mechanical links.
    The tech is commonly used in aeroplanes, but the Japanese firm said it would be the first to apply it to mass-produced cars.
    However, it might need to overcome motorists' safety concerns.
    Although the vehicles would still be controlled by a human, one analyst said the development could eventually be incorporated into driverless cars.
    Controlled feedback
    Nissan said that users would benefit from an improved driving experience since their intentions would be transmitted to the wheels faster than by using a hydraulic and mechanical system.
    In addition it suggested that the development would "insulate" motorists from disturbances caused by unnecessary feedback.
    "For example, even on a road surface with minor ridges or furrows, the driver no longer has to grip the steering wheel tightly and make detailed adjustments, so travelling on the intended path becomes easier," it said in a statement.
    Some car buyers may be wary about the idea of putting their lives in the hands of a computer system after other related efforts proved problematic.
    In 2004 Mercedes-Benz faced customers complaints that its Sensotronic brake-by-wire system - which used an electrical link to control vehicles' brake pads - sometimes failed.
    Although the vehicles had a hydraulic back-up it meant some owners had experienced longer stopping distances.
    The firm ultimately recalled about two million vehicles and dropped the feature.
    More recently Toyota had to ask Prius owners to take their cars into garages to install a software update after reports some models had suffered from "inconsistent brake feel".
    Nissan said its Infiniti-branded vehicles would be first to be fitted with steer-by-wire technology
    Nissan appears to have borne these issues in mind by deciding to install a back-up clutch system in its steer-by-wire vehicles, to link up their steering wheels and tyres in the event of a problem.
    However, it signalled it hoped to be able to ditch the safety measure in the long term.
    "If we are freed from that, we would be able to place the steering wheel wherever we like," said Masaharu Satou, a Nissan engineer.
    "Such as in the back seat, or it would be possible to steer the car with a joystick."
    For the time being the addition of the clutch system adds back weight to the vehicles, undermining another potential benefit of the technology - better fuel efficiency.
    Driverless cars
    Jay Nagley, managing director of the Redspy auto consultancy, said he thought the development would catch on.
    "I think initially people will find it a bit spooky but will be reassured by the fact there is a mechanical back-up if required," he told the BBC.
    "But over time I'm sure people will get used to it as its part of the bigger picture of self-driving cars where drivers don't have to be in control at all times."
    Volkswagen has already tested drive-by-wire technology in a modified version of its Passat model that has driven itself along Berlin's roads.
    Volvo has also incorporated the facility in tests of its self-drive "road train" concept, which involves a convoy of cars using drive-by-wire tech to mimic the actions of a lead vehicle.
    BBC News - Nissan steer-by-wire cars set for showrooms by 2013
  • darrenhyland
    • 1124
    i for one will never drive one of those...EVER!!!
    Tools owned..... Kess3 Master, Bitbox, TGFlash, VVDI2 Full, VVDI Prog, VVDI MB Tool, VVDI Mini Tool, VVDI Key Tool Max Pro, VCX series for BMW Ford Mazda Jaguar Land rover VAG Toyota Volvo GM, PCM Flash + Scanmatik2, Lonsdor K518ise, Magic tank and every other piece of Chinese crap out there.
    • gizmo.1484
      • 873
      Originally posted by gmb45
      "Such as in the back seat"
      Why would you want the steering wheel in the back seat?
      Back seat drivers are bad enough
      • Canker_Canison
        • 3905
        I'll take one.
        Can I fit my xbox wheel with forced feedback into the car?
        Gran Turismo for real
        Canker
        [COLOR=Green]
        • Cod3waX
          • 1011
          bring on the joystick
          hope the reset button works too
            OFF TOPIC:-
            [ame=http://www.youtube.com/watch?v=AJOqUFjMfcY&feature=related]Troopers escort driver after accelerator gets stuck - YouTube[/ame]
            INFERIOR WEBSITE CONTRDICTING ABOVE VIDEO
            ON TOPIC ISH:-
            OK so on a gas pedal they ALWAYS have two inputs, a positive input and a minus input.
            So say you want 50% throttle, you get a "+50%" signal and a "-50%" signal. So the ecu is SURE it knows what your doing.
            So how does this thing work?
            DAMM IT:-
            Rumor going aroing approx 1990 JCB 3CX, if your busy making sppol valve noises, FFFFSSSSHHHH, PPPSSSSSSHHHHHH as you work the controls, if the from loading shovel, doesn't seem to stop coming up, you need to
            1) Shut the motor off ASAP
            2) You do run run, you do run run.
            If you don't RUMOR has it the arms go over the cab roof.
