Barcode Scanner
  • SouthernComfort
    • Feb 2011
    • 403
    Barcode Scanner
    Barcode Scanner
    *Available on Android Market(Free)*
    Scan barcodes on products then look up prices and reviews. You can also scan Data Matrix and QR Codes containing URLs, contact info, etc.
    Also share your contacts, apps, and bookmarks via QR Code. This is why contacts permissions are needed.
    Main use, scanning QR codes for easy access to apps.
    Permissions
    Hardware Controls
    Take Pictures and Videos
    Allows application to take pictures and videos with the camera. This allows the application at any time to collect images the camera is seeing.
    Network Communication
    Full Internet Access
    Allows an application to create network sockets.
    Your Personal Information
    Read Contact Data
    Allows an application to read all of the contact (address) data stored on your device. Malicious applications can use this to send your data to other people.
    Write Contact Data
    Allows an application to modify the contact (address) data stored on your device. Malicious applications can use this to erase or modify your contact data.
    Read Browser's History and Bookmarks
    Allows the application to read all the URLs that the Browser has visited, and all of the Browser's bookmarks.
    Storage
    Modify/Delete USB Storage Contents Modify/Delete SD Card Contents
    Allows an application to write to the USB storage. Allows an application to write to the SD card.
    System Tools
    Modify Global System Settings
    Allows an application to modify the system's settings data. Malicious applications can corrupt your system's configuration.
    Change WIFI State
    Allows an application to connect to and disconnect from Wi-Fi access points, and to make changes to configured Wi-Fi networks.
    Prevent Device From Sleeping
    Allows an application to prevent the device from going to sleep.
    Barcode Scanner QR (working example)
    Rename file .rar > .apk, send to SD, Install. Available free on market.
    "What we've got here is failure to communicate."
