Hello ive got a samsung s4 I've downloaded xbmc to it ive installed navi x to it but I dont no how to watch s** sport or movies does any body no what there doing and could help me out I will be more than greatful Thanks for reading
XBMC
look for a plugin called ontapp tvguide.....It used to be called dixies tv guide so if you google either of them it will take you to the correct site you then go to mashup and do the equivilent of right click whatever that is on the s4 and selct add to dixie/ontapp then choose the correct channel that matches the stream from teh dropdown that appears, then when you open the ontapp plugin you will have a tv guide that you can just choose your desired channel from and the stream you set earlier will playComment
yes, you need a ontapp tvguide plugin.look for a plugin called ontapp tvguide.....It used to be called dixies tv guide so if you google either of them it will take you to the correct site you then go to mashup and do the equivilent of right click whatever that is on the s4 and selct add to dixie/ontapp then choose the correct channel that matches the stream from teh dropdown that appears, then when you open the ontapp plugin you will have a tv guide that you can just choose your desired channel from and the stream you set earlier will playComment
ive got navi x on there and mash up.wana no how to get every s** channel on there n in 1 list
