Torque Pro 1.8.49 MOD by masterlist (Android) whit plugins
  • rewalex
    • Aug 2013
    • 43
    Torque Pro (OBD2)1.8.49 MOD
    plugins:
    Hyundai
    kia
    fiat
    MItsubishi
    nissan
    Reno
    no pass required
    I have more things for this app, if some one need widgets or need some .csv.Please write to me
    please rate this post if is helpful or Not .
    Best regards
    I'm not a pirate, I'm a starving seafarer
  • bandit boy
    • 155
    I use torque a lot it is very good is it possible that you have ford and vw plugins thanks very much
    • rewalex
      • Aug 2013
      • 43
      ford some time have problems whit J1850-PWM protocol(whit Bluetooth adapters), if is not working ,You must to change the adapter.
      to work without problems whit protocol lISO-9141, ISO 14230 (KWP2000) ISO 9141 on BMW, OPEL, WV, AUDI, SKODA, VOLVOVAG you need COM 409.1
      Mazda ecu is similar if you are Lucky by work .
      must clean lvl Mazdaspeed whit LukyPatcher (ROOT requered)
      Racing Meter inside .rar
      [HIDE] ? Digital Gauges for RPM, Speed, Engine coolant temperature, Intake Air  temperature, Catalysts temperature, Engine Load, Turbo boost, Fuel  Consumption, Clock, Fuel pump and Rail pressures (gauge and relative  pressure).
      ? ****og Gauges with Auto Scale, Warning and fully  Customizable style, scale, angle, size and warning thresholds. For RPM,  Engine Load, Turbo boost, Engine coolant temperature, Intake Air  temperature, Speed, Catalyst temperatures, Fuel pump and Rail pressures.
      ? RPM LEDs Bar
      Customizable  colors, four styles and three animations available. Automatic or manual  threshold settings. Two additional LEDs Bar are available to display  Turbo, RPM or Load data.
      ? Gear Estimate
      This value is calculated with the speed and RPM values.
      ? Customisable dashboard & profiles
      Layout  your own dashboard. Move, rescale, add or remove any parameters, three  different layout profile can be saved and number of screens can be  increased up to five. Frame and LEDs style fully customizable.
      ? Shift Light
      Flash on screen, Automatic or manual threshold and color settings.
      ? Telemetry Viewer
      Display  Telemetry in real-time and save up to one hour of data. Two cursors can  be placed on the graph to measure the time between two points.
      The following data are recorded:
      Speed, RPM, Gear, Engine load, Turbo boost, Lateral forces, Longitudinal forces.
      ?  Import/Export the telemetry data as a CSV file on your sdcard for  further calculations. Export to RaceRender format supported with the  following data: Time, GPS Latitude, GPS Longitude, Speed, G-Forces, RPM,  Throttle position, Gear, Turbo.
      ? Heads up display / HUD mode for night time driving.
      ? G-Force Meter (plotted 5s)
      ? Acceleration measures
      Current and Best acceleration Widgets based on speed or distance. You can define the thresholds.
      [B]Units available:[/B]
      Mph/Kmh ; ?C/?F ; psi/kPa/bar ; LPK/KPL/MPG [/HIDE]
      • rewalex
        • Aug 2013
        • 43
        mate try this, may be it be work whit ford and wv
        [HIDE] http://www.digital-kaos.co.uk/forums/showthread.php/470553-DashCommand-%28OBD-ELM-Scanner%29-v4-6-3-%28Full-Version-All-IAPs-Unlocked%29?p=2519098#post2519098 [/Hide]
        • miniman1
          • Jul 2014
          • 11
          Thanks also available on aptoide
          • djmacedin
            • Feb 2016
            • 17
            have you got any csv files for subaru thanks
            • Roy Suryadwiananda
              • Jul 2010
              • 1428
              Hello, i need for Toyota Hilux.apk , if you have please to share for us.
              Thanks .
              Please follow this link :
              http://www.digital-kaos.co.uk/forums...oduce-Yourself
              • jsg1200
                • May 2013
                • 36
                Thanks!
                Regards
                • keboid
                  • Feb 2018
                  Is this really working for ford?
                  • alamicx
                    • Feb 2010
                    • 5
                    obd interfate is elm 327 (i think) and for ford specialy diesel is not working. for petrol is ok
                    • Falcoverde76
                      • Oct 2019
                      • 13
                      Thanks man
                      • quentinz
                        • Nov 2019
                        Nice mod just what i been looking for, appreciate it
                        • winux19
                          • Feb 2021
                          • 18
                          thank you good sharing
                          • sxp88
                            • Jun 2021
                            • 20
                            thanks ......
                            • DesmondSmith
                              • Jul 2021
                              Whats the difference between "Free Value pack" and Pro version?I have just seen an announce into the free app to have value pack for 1,19 whereas Pro version is 5,99 Its for Android.
