This is for root only and is not a custom rom. I accept no responsibility if anything goes wrong. Remember to read everything. I am using this method as apposed to a one click method as it will stand you in good stead if you decide to flash a custom rom or mess things up in the future and have to flash back to stock.
THIS WILL VOID YOUR GUARANTEE
Always unmount and remove external sd card before flashing.
First make sure you can boot into recovery and download using the three button method. For recovery this is (with phone off) hold down volume up and home button (middle one at the bottom) then press and hold power button until phone boots. For download this is volume down home button then press and hold power button to exit recovery navigate to reboot now using volume up and down buttons and select with home button. To exit download just hold down power button.
Next step is to download the drivers for your phone
windows 64bit
Download Samsung Galaxy S USB Driver for Windows x64 Driver for Windows XP X64 / Windows Vista64 / Windows 7 x64 - Softpedia
windows 32bit
Download Samsung Galaxy S USB Driver for Windows x86 Driver for Windows XP / Windows Vista / Windows 7 - Softpedia
1. Extract the CF-Root-your version.zip
2. Open Odin. KIES MUST NOT BE RUNNING, IT WILL MESS UP YOUR PHONE.(Odin must be opened before connecting phone to pc) odin download link Odin3 v1.7.exe
3.Click on PDA button in odin and select the CF-Root-your version.tar that you extracted in step 1 (DO NOT CHECK REPARTITION)
4.Boot the phone into download mode
5. Connect phone to the pc and wait until there is an entry in the ID:COM
6.Once the entry has appeared click start
7. DO NOT PLAY WITH PHONE, REMOVE THE USB CABLE, RUN OUT OF ELECTRICITY OR DO ANYTHING ELSE THAT MAY INTERRUPT THE FLASH PROCESS (it doesn't take long) The phone will reboot once flash is complete.
Here are the CF-ROOT-Files...YOU MUST USE THE FILE THAT MATCHES THE LAST THREE DIGITS OF YOUR CURRENT VERSION eg.XWJVH USES THE JVH file and so on.
CF-Root-XW_OXF_JS2-v1.3-BusyBox-1.17.1
http://www.filesonic.com/file/118178...Box-1.17.1.zip
http://www.wupload.com/file/14406715...Box-1.17.1.zip
CF-Root-XW_XEN_JS3-v1.3-BusyBox-1.17.1
http://www.filesonic.com/file/118176...Box-1.17.1.zip
http://www.wupload.com/file/14400141...Box-1.17.1.zip
CF-Root-XW_XEN_JS5-v1.3-BusyBox-1.17.1
http://www.filesonic.com/file/118173...Box-1.17.1.zip
http://www.wupload.com/file/14388125...Box-1.17.1.zip
CF-Root-XW_XEE_JS7-v1.3-BusyBox-1.17.1
http://www.filesonic.com/file/118171...Box-1.17.1.zip
http://www.wupload.com/file/14387395...Box-1.17.1.zip
CF-Root-XX_DBT_JQ3-v1.3-BusyBox-1.17.1
http://www.filesonic.com/file/118169...Box-1.17.1.zip
http://www.wupload.com/file/14386939...Box-1.17.1.zip
CF-Root-XW_NEE_JS8-v1.3-BusyBox-1.17.1
http://www.filesonic.com/file/118157...Box-1.17.1.zip
http://www.wupload.com/file/14382848...Box-1.17.1.zip
CF-Root-XX_OXA_JVK-v3.1
http://www.filesonic.com/file/118155....1-CWM3RFS.zip
http://www.wupload.com/file/14381985....1-CWM3RFS.zip
CF-Root-XW_XEE_JVB-v3.1
http://www.filesonic.com/file/1181519764
http://www.wupload.com/file/14380894
CF-Root-XW_NEE_JVH-v3.2
http://www.wupload.com/file/14380504....2-CWM3RFS.zip
http://www.filesonic.com/file/118147....2-CWM3RFS.zip
CF-Root-XX_OXA_JVO-v3.2
http://www.filesonic.com/file/118145....2-CWM3RFS.zip
http://www.wupload.com/file/14378945....2-CWM3RFS.zip
CF-Root-XX_OXA_JVP-v3.7
http://www.filesonic.com/file/118129....7-CWM3RFS.zip
http://www.wupload.com/file/14376560....7-CWM3RFS.zip
windows 64bit
windows 32bit
