S3 LTE I9305 firmware issues
  • hkphooey
    • Apr 2010
    • 232
    Hi guys
    I am pulling my hair out here i have a LTE S3 in UK but have messed up a root some how...Now all it does is go into "Downloading..."Do not turn off target" when i switch it on
    It will go into odin mode but i am not sure what i have to do and which firmware i need... All firmwares official seem to take hours and hours to download or find
    PLEASE can anyone help.
    Cheers
    Hk
  • Squadr33
    • Aug 2013
    • 129
    there are a few things you can try, did this happen after trying to root your phone or did you try to flash a stock rom? did you make a full backup before ?
    option 1) if you made a backup, try and start phone in recovery mode, do full wipe, format sd and wipe cache/dalvik etc (basicly restore to factory settings)
    option 2) you can download and install Samsung KIES, open KIES, connect with your S3 and try to select emergency recovery. (slow but save)
    option 3) if you cant get in recovery mode or KIES recovery wont work you can find the firmware you need here: Firmware archive | Samsung Updates
    and flash using odin or ADB
    good luck and let me know if it worked or you need more help
    greetings from the Netherlands
    " You can’t be a true petrolhead until you’ve owned an Alfa Romeo " - Jeremy Clarkson
    • Canker_Canison
      • 3905
      Or you could try removing the volume buttons from the case.
      I've seen a few phones where one of the volume buttons has been jammed down, causing the phone to enter either the boot menu or download screen every time it's started.
      Canker
      [COLOR=Green]
      • Squadr33
        • Aug 2013
        • 129
        never seen that myself but its a very good option to try before taking other more serious steps
