Samsung J510FN
  • ilen
    • Feb 2013
    • 1536
    Samsung J510FN
    Hello,
    Samsung J510FN will not start, just flashes, samsung on screen. after that i wrote the firmware with Odin3, but the same. can anybody help me...
    Thenxx...
    Послато са SM-J500FN уз помоћ Тапатока
  • jodge
    • Mar 2017
    • 1757
    - Go to reco menu and check the current sw version on the firs (second) row
    - Choose the same or higher unbranded version (J510FNXX......unbranded or J510FNXE... the slavic)
    - Use the 4 file version flash, if you have 5 files (2 kind CSC) use the regular not the HOME_xxxxxx
    - After succesfully flash go to recovery menu and perform hard reset
    If the phone still not starting it means probably 2 thing:
    - The EFS is damaged /erased = you can't do anything w/o proper tools --> samsung service centre or skilled independent service (the main reason is w/o MSL code or other paid service the cable unlock is impossible but some "smart" guy well...."smart" )
    - The phone hw is damaged, mostly the emmc going bad or the built-in RAM it means the authorised service center will change the main pcb for free if the warranty is intact
    Sir, are you classified as human? Negative, I am a meat popsicle
    • ilen
      • Feb 2013
      • 1536
      I only have Firmware J510FNXXU2BQJ8 2,8 GB, I put it in PA.
      After succesfully flash go to recovery menu and perform hard reset, but update only 32 % , ... and stop....
      • ilen
        • Feb 2013
        • 1536
        • jodge
          • Mar 2017
          • 1757
          if knox isn't tripped or disassembled drop back to warranty. It seems the emmc is gone.
          • ilen
            • Feb 2013
            • 1536
            I need a BL + AP + CP + CSC file for this J510FN or a link to downland....
            Thenxx...
            • jodge
              • Mar 2017
              • 1757
              It's available only in paid support. You can pay via paypal on many site.
              or send me your current sw version. You can check it on the recovery first-third row.
              • jodge
                • Mar 2017
                • 1757
                BTW your phone originally from Italy , sold on 2016.05.12 with 1 year warranty
                According the service bulletins your problem could be:
                - Bad lcd (yes even w/o any mark of damage)
                - Qualcomm PMU (power management unit)
                - Emmc (mostly it's flip to write protected mode)
                - And sw related problems
                • mobileunlockers
                  • May 2013
                  • 96
                  problenm with EMMC Chip, Either bootloader damaged or Emmc reballing.
                  • jodge
                    • Mar 2017
                    • 1757
                    if the bootloader is damaged there is no download mode at all.
                    In this case the cpu core loader couldn't pass the boot chain to the SBL and the qulacomm EDL port is appears (QCHS-9008)
                    • bebiloku
                      • 215
                      tray to use Samsung software by sn
                      • bebiloku
                        • 215
                        samsung smart switch
