dependencies not met
  • pudzy
    • 206
    hi guys, i got one of these smart tv box... trying to get it working with kodi.. but no joy... http://spartan.pixel.net/repo but its doing my head, i have try different images like kodisrael, and so on... but im wondering is there something else my problem... like setup. im connected via wired.. any help be great
  • pudzy
    • 206
    just did a factory reset on box.. and on reboot. im getting Addon has been marked as broken in respository . ?? would you like to disable it on your system,,
      First question what make of Box do you actually have as in M8,MQ etc..
      • pudzy
        • 206
        thanks for reply m8... ok, iptv 18 smart tv box.. is all the info on the box.. it Android that all i no m8... i have kodi on the box.. i have just googled and it looks very like MQ . . but i cant be 100% digicon
          it sounds like this Box here:
          http://www.acemax.net.cn/droid-world/droid-box/amlogic-8726-mx-cpu/iptv-18-pro-dual-core-83.html#.VkOOW9LhCUk
          To get a later version of Kodi on there it looks like you may have to manually upgrade your android version files here:
          http://www.acemax.net.cn/downloading-center/acemax-products-sw-downloading-center-14.html
          IPTV 18 Pro Dual Core
              201406 Version(XBMC Gotham Version, and XBMC on launcher and on main page)
              https://mega.co.nz/#!IptXQCjC!MiP20aIdm2wWxMHXSBG8Whlsv3jQD3kD42O1KdQrpX4
          IPTV 18 Pro Updating Procedures:
          1) Uncompress the downloaded firmware (ROM) to the root of and SD card
             (format your SD card first).
          2) Insert the SD Card into powered-off Box (power cable not plugged in) with no external
             USB storage attached.
          3) Using a toothpick, insert into the A/V port of Box, press and hold the hidden button while
             plugging power in.Do not release until you see the screen of Robert Logo.
          4) Update will run automatically. When it is done then choose ?Reboot?. You can disregard
            any errors that display after the update, they are not relevant to your device.
          5) When system has rebooted then you should first check to ensure wifi is working by going
           to Settings->Wi-Fi. Turn on the wifi if it?s off and you should be able to connect.
          You may also have to loook at some form of custom ROM install to get a later version of Kodi, Google brings up plenty of links
          • pudzy
            • 206
            sorry digicon, i just clicked on service,settings,general, devive name = XBMC
            AND THAT LINK DIDNT WORK
            X96S X96 MAX TX5 MAX ACEMAX M12N K1 PLUS S2 T2 KIII KII M8S+ IPTV 18 PRO,M8, M8N M8S M12 M10 Upgrading Software Download
