IPad not connecting to home WiFi?
  • hotlife
    • Oct 2011
    • 50
    When i try to connect my ipad 2 to my wifi at home it appears to connect but then when i try to access the internet a message comes up saying "safari could not open the web page because it is not connected to the internet". the wifi signal bars at the top show but when i go on the wifi options and click on my wifi to connect to it, the little loading circle appears and it does not stop loading, and the tick that shows you are connected to the netwirk does not appear! it used to work fine until it sudddenly stopped, and the wifi works fine on my laptop, just not on the ipad. thanks for any help.
  • paksi
    • Jan 2012
    • 4
    try to update
    • donegalvolvo
      • Oct 2011
      distance?
      Maybe you are too far away from the wireless router? I'd go right beside it to be sure.
      But I would make sure to power down fully the ipad then restart.
      If that doesn't work it may be a dhcp issue and it for some reason is not giving you out an ip address.
      hope that helps!
      • mouss800
        • Apr 2010
        • 46
        just try to reset networks on ipad , may be ip conflicting with other devices at home
