water damage iphone 3gs, help
  • mikie64
    • 118
    hi just got a.3gs everything works ,connect to itune,make the right noise went usb is connected,it evens show the green battery sign,,....but the phone will not charge..[.it not the dock port] any help?
  • Canker_Canison
    • May 2010
    • 3905
    It can still be the charge port, but more than likely the battery needs replacing.
    Just to explain, the charge port is connected to the main board by a ribbon with a push connector. It's more than likely there's residue & corrosion on that connector.
    Take the phone apart, buy some 99.9% IPA off ebay. Get the wife's toothbrush & scrub the board socket & the ribbon connector. Remove the metal covers & scrub what you can with the IPA. Do not touch the digitizer or LCD with the IPA, just the connectors if needed.
    Dry it with a hot air gun or hair dryer.
    Put it back together & try it again.
    Videos are available on taking the 3GS apart on you tube.
    Still no joy, order a battery. If the current battery is swollen it will need replacing no matter what.
    Canker
    [COLOR=Green]
    • mikie64
      • 118
      thanks mr canison .up and running now..but the misses wants words with you,,,,,,,
