3gs problem
  • smirnoff_rules
    • 8603
    3gs problem
    my m8 got an 3gs and was havin network problems and he did a full reset and phone did nothing after an hour and stuck on apple , lm trying to restore on itunes and it only gets 10% though and stays there no errors just hangs there ,, thied on different pc 's and the same . is there another way to flash f/w onto it ?
  • Devilfish
    Administrator
    • Feb 2008
    • 7872
    That's happened to me a few times when updating Cydis, just sits on the apple screen after rebooting. I had to reset it with the home button and power button together and it took about 10 minutes to reboot.
    Have you tried disabling your AV and Firewall?
    • fijiman
      • Oct 2010
      • 976
      Did he try an iPad baseband unlock before updating..?
      • smirnoff_rules
        • 8603
        it was jaibroke with poison on 4.2.1 and unlocked with snow , cant understand why it will not restore tho
        just hangs here no errors tho ?
        • smirnoff_rules
          • 8603
          no m8 its was 1.650 something like that and re set on the phone in setting not on the pc
          • smirnoff_rules
            • 8603
            it wouldnt reboot after he wiped it so l just though l would restore and update to 5.0.1 . l even download ipw f/w but just gets so far
            • fijiman
              • Oct 2010
              • 976
              This looks like 06.15.00 baseband....which is the iPad version....
              Try building a custom firmware using Sn0wbreeze and upgrade that way...
              • smirnoff_rules
                • 8603
                ok my will do . its says after 2 minutes this below .. its the 3rd one l have download and itunes see the ipsw ?
                • fijiman
                  • Oct 2010
                  • 976
                  Have you got the correct firmware(.ipsw) for the 3gs...?
                  • smirnoff_rules
                    • 8603
                    yes m8 iPhone2,1_5.0.1_9A405_Restore it starts to run and then that picture comes up
                    • fijiman
                      • Oct 2010
                      • 976
                      Are you using the correct Sn0wbreeze..? 2.8beta11..?
                      • smirnoff_rules
                        • 8603
                        downloaded iPhone 3GS-5.0.1_BB6.15.00_Activated_www.iPhoneRock.com_2 and installed all the way but at the end it was itunes says updated and restarting phone and it still hangs at a update screen on the phone still ?
                        got this to work and jailbroke but as its modified ipsw its a tethered jailbreak but installed coron or something like that and it reboots untethered now.. cheers .. nightmare that was
